Old 10-09-2009, 02:34 AM   #1 (permalink)
White 4Runner - '98 Toyota 4Runner SR5
90 day: 23.21 mpg (US)
Grey Jetta TDI - '11 VW Jetta
90 day: 39.17 mpg (US)
Computing FE Question
When computing your MPG do you use the odometer in your car or go off the ScanGaugeII? Just discovered that due to non stock tires that I had to adjust the speed on the ScanGauge +2%. I computed the difference and then confirmed it using a GPS and the SG set to KPH. So do I use the mileage from the SG from now on?
Old 10-09-2009, 02:36 AM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
According to some the SGII can go sightly out of whack over time, so I just use fillup, since even small variations will eventually filter out.
Old 10-09-2009, 02:39 AM   #3 (permalink)
I guess my question is do I use the tank mileage from the SG or still use the odometer? The odometer will report 2% fewer miles then actually driven.
Old 10-09-2009, 10:20 AM   #4 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 60.16 mpg (US)
I apply a correction to my car's odometer reading when calculating fuel economy of each tank.
My odometer reports lower than actual, due to swapping the transmission from a model that had different size tires.
I also have a speed (distance) offset entered in the ScanGauge, but it's less accurate than my own calcs against the odometer because you can't enter tenths of a percent when entering the offset.
Old 10-09-2009, 12:02 PM   #5 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
srortega -
I have the same +2% issue. I use my odometer and I calculate the +2% in my fuel log. It's like a little bonus every time I enter my fill-up data.
CarloSW2
American Solar Energy Society
Driving the Scanguage for FE Harry6 Hypermiling / EcoDriver's Ed 12 04-02-2010 12:51 PM
Effect of fuel octane number on FE hummingbird EcoModding Central 32 10-28-2009 12:50 AM
FE Acceleration thought experiment. TestDrive Hypermiling / EcoDriver's Ed 2 01-28-2009 10:24 AM
Looking at buying a civic vx. FE question yoshimitsuspeed General Efficiency Discussion 2 07-23-2008 06:50 PM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
