Originally Posted by Joenavy85
i thought of that, but it would block the lower grill opening, i already have the upper grill about 70% blocked
The brackets won't be that wide to block the lower opening...maybe 1" wide each? Some 1/8" steel flat bar would work...
You could even remove the front hooks and just use those existing bolt points.
You'll still need to brace the air dam so the air doesn't push it back or fold it over. What sort of materials are you planning to use?
I guess if you git really creative, you could probably hook the top of the new air dam onto the hooks and then secure the bottom with some other brackets. Would make it easier to put on/take off...
