Old 07-31-2011, 09:57 PM   #21 (permalink)
Learning quick
Good Altima - '06 Nissa Altima 2.5s
Originally Posted by EdKiefer View Post
I doubt very much you could do that without firmware update "if" ECU the same .
well the base 1.8L in 3400lb vehicle sound like it be slugish . I think I would get something else, lighter . hell even accord 2.4L is only 3100-3200 in low trim .
the 1.8 liter base model is 3150 lbs roughly. Im a hypermiler, so sluggish is what I do anyways. Its my driving style. The front grill is black and all i do is use gorilla tape on the grills for a block and I will install my scan gauge 2 and use my PSI inflation strategy to match the ECO's mpg. The accord is not as good on gas and it is more expensive.
I tend to look at best value for money. And I care about safety since I have a little one. The Cruze is a smart compromise in every category in my opinion. At 17000 CAD... In my opinion its a steal.
When I look at a new purchase I look at maintenance cost. Safety. (if you're dead hypermiling means nothing) MPG, Insurance cost, Since te base isnt a turbo model ins will be cheaper.
Old 08-01-2011, 06:18 AM   #22 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by cfg83 View Post
Maybe you could slowly get your hands on the Eco aero-options over time. I would hope that the closing grill could be just "hooked up" and the ECU/PCM would recognize it and use it, but maybe that's asking the software to be too flexible.
Nothing a (partly) (removable) grill block can't solve
I'd have it delivered with good LRR tyres, if the regular Cruze doesn't come with them as stock.
Being in Canada, you could get the Michelin Energy Saver LRR tyres.
IMO the best compromise between eco and fairly decent handling.
