Old 12-30-2016, 08:02 PM   #61 (permalink)
Why a holley carb?
They are not really known for fuel economy so much.
Old 12-31-2016, 12:16 AM   #62 (permalink)
me and my metro's Avatar
Economy Saturn - '02 Saturn L200
We didn't have much luck with an annular discharge 650 two barrel on our 265" straight six. We had great success with a 500 two barrel. We spun it 8000 rpm in a six cylinder stock car class back in the 70s.
02 Saturn L200 5 speed- 265k miles
84 Gmc 6.5 na diesel K30 4x4, TMU
2006 Lincoln Navigator, 215k miles
Old 12-31-2016, 12:41 PM   #63 (permalink)
Have you given any thought to using a 32/36 DGEV Progressives Weber (Holley/Weber 5200)?
Old 12-31-2016, 09:00 PM   #64 (permalink)
The key to carb performance is air velocity which keep the fuel droplet in suspension. It must be selected for size to give 1/4 the speed of sound at Maximum HP.
Old 01-01-2017, 07:41 PM   #65 (permalink)
AeroGuy
eco_generator's Avatar
Outback 14 - '14 Subaru Outback Limited
90 day: 23.1 mpg (US)
Holy moly, who figured that out??
Old 01-02-2017, 11:46 PM   #66 (permalink)
I have had Performance Trends engine analyser for about 4 years. I use to build string instruments and understand the importance of air waves. I noticed one day that most engines that I built were making max HP at about 280 to 290 ft./sec. This does change with altitude also.
To better understand intake flow we must understand frequency science. Studying harmonics and wave length will help understand.
My Hypothesis is maximum torque is largerly influenced by CID, cam prohile, compression and intake port cross sectional area. Maximum torque is also influence by intake port length and Plenum Volume.
Read this article will help.
http://www.chrysler300club.com/uniq/allaboutrams/ramtheory.htm
Old 01-04-2017, 08:29 PM   #67 (permalink)
Buggie - '01 Vw Beetle TDI Gls
Why not a DIY efi setup, with on board laptop so you can play with your fuel mixture on the fly
Old 01-07-2017, 06:11 PM   #68 (permalink)
I am very much considering a 4.3 TBI setup using Megasquirt 2. It seems to be versatile. How much more mpg would I get. ???
Old 01-08-2017, 12:05 PM   #69 (permalink)
If you got your carb and distributor dialed in at cruise I would expect the same mileage. However the tbi/ megasquirt system will instantly adjust for all other conditions. So overall you will see significantly better mileage overall. Carbs have three modes: idle, cruise and power. Tbi have infinite modes.
Old 01-08-2017, 12:40 PM   #70 (permalink)
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
+1 more on 4 barrel and some 2 barrels , secondaries they can be progressive (what an Ecomodder would use) and 1:1 (race use). My 82 gmc Jimmy s-15 was basically a 4-barrel carburetor cut in half front to back.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
