Old 09-07-2018, 04:01 PM   #81 (permalink)
Excellent job on the hole for the hitch. I am impressed.
NeilBlanchard (12-18-2018)
Old 12-18-2018, 02:03 PM   #82 (permalink)
Thanks - all the credit goes to my brother, for this.
For the gearheads among us - here is a detailed teardown of the Bolt EV motor and transaxle:
Chevrolet Bolt EV Traction Motor – Deep Dive: Video
The Following 5 Users Say Thank You to NeilBlanchard For This Useful Post:
aerohead (02-06-2019), Daox (12-18-2018), easythereturbo (12-18-2018), samwichse (01-15-2019), sendler (12-19-2018)
Old 12-18-2018, 03:29 PM   #83 (permalink)
I could use a hitch too.
One year later.. here I'm still wishing I had that coasting setting.
99% bev now
1% other junk
Old 12-19-2018, 12:34 PM   #84 (permalink)
I am ordering a hitch later today! The TorkLift Ecohitch is the only one with a 2" receiver.
Old 01-14-2019, 06:13 PM   #85 (permalink)
I installed the same model hitch on our Bolt EV, on Saturday. I did it on my own (my brother was moving with his wife from her house, to his), so I didn't take any pictures. Here's the post of the installation of his:
https://ecomodder.com/forum/showthre...tml#post578132
I also bought a Curt T-One trailer light connection harness, and therein is a tale. The unit is designed for the Chevy Volt, and said that it fits a Chevy Bolt, as well. It does have to correct connectors, that T into the left and right light groups that are in the bumper of the Bolt EV.
Two problems became apparent, though. Here's my email that I sent to TorkLift:
I received the T-One connector a few days ago, and I finished installing it today. It is made for the Volt - and it is supposed to "fit" the Bolt EV; which is what I have. While it does "fit" - it has two fairly serious issues:
The location of the 12v battery in the Volt is in the back, under the floor of the hatch area (where a spare tire is often located). So the wire on the T-One that connects to the battery is roughly 3 feet long, or so. The 12v battery in the Bolt EV - is up in the front of the car, under the hood, on the driver's side - where many if not most, are located. I had to add 16 feet of 12 gauge wire to be able to connect to the positive terminal; and I needed to make 2 splices, so I could keep the 10A fuse in place.
The second issue is a bit more subtle. While the Volt is a hatchback, it's taillights are located on the body of the car. The Bolt EV is a hatchback as well - but it's main taillights / brake lights are located on the *hatch door* itself. The turn signals are located in the bumper. The issue is that by law, there have to be "alternative" tail / brake lights on the body - for when the hatch door is open. This is because, if the door is all the way open, the lights would not be visible.
So, basically, I have to open the hatch door, in order for the trailer tail / brake lights to function. The T connections on the unit do "fit" in that they plug into the left and the right side lights *on the bumper*. I don't know where to find the connectors for the lights in the hatch door - and the turn signals are in the bumper, anyway. They are probably too far away for the length of wires on the T-One unit you provided.
I hope this all is clear - if you have questions, I'd be happy to answer, if I can. I think you need to not sell this unit for the Chevy Bolt EV, and hopefully Curt can make one that does have 1) a long enough wire to reach the 12v battery, and 2) connectors AND INSTRUCTIONS to connect it properly to the Bolt EV *without* having to tow a trailer with the hatch door (slightly) open.
Old 01-14-2019, 06:48 PM   #86 (permalink)
90 day: 29.78 mpg (US)
I've resorted to tapping into the light harness itself and using LED trailer lights, which won't overload the circuit. I can't see using a controller and wiring in power and a fuse when the necessary wires are already there. Would be nice to get T-plugs so I don't have to pierce the stock wiring, but that's a minor issue.
Old 01-15-2019, 06:59 AM   #87 (permalink)
sendler's Avatar
90 day: 105.14 mpg (US)
90 day: 60.68 mpg (US)
90 day: 38.51 mpg (US)
PCX153 - '13 Honda PCX150
90 day: 104.48 mpg (US)
90 day: 80.94 mpg (US)
90 day: 72.57 mpg (US)
I've resorted to tapping into the light harness itself and using LED trailer lights, which won't overload the circuit. .
Any issue with bulb monitoring giving false warnings?
Old 01-15-2019, 11:38 AM   #88 (permalink)
Nope, although I don't know if any of my vehicles are that smart (Prius).
Old 01-15-2019, 12:55 PM   #89 (permalink)
The T-One does not cause a bulb warning. I was tempted to use the plugs, and tie them directly to the 4 pin connector, but at first at least, I am borrowing my brother's trailer which has conventional bulbs.
And I would still have to crack open the hatch door.
Old 08-23-2019, 08:04 AM   #90 (permalink)
The 2020 Bolt EV gets a 10% larger battery - 66kWh! And a higher range of 259 miles.
https://insideevs.com/news/366579/20...9-miles-range/
samwichse (08-23-2019), Xist (08-23-2019)
