Old 09-29-2016, 08:08 PM   #1 (permalink)
24 Grom - '24 Honda Grom
90 day: 121.66 mpg (US)
Clover - '61 VW Beetle Vert
90 day: 24.27 mpg (US)
Rosie - '61 VW Beetle Sedan
90 day: 24.23 mpg (US)
Upper Grill Block
Ok so I made a template today out of cardboard for the upper grill block here is my only question? Is it ok to leave it on the back side or do I have to put it on the front of the grill?
Old 09-29-2016, 08:30 PM   #2 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
I think the backside is fine, but you have make sure it's secure enough not to be blown open by air pressure.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
aerohead (10-01-2016)
Old 09-29-2016, 08:53 PM   #3 (permalink)
Yes I have about 8 spots I'll hold with zip ties to the front grill. Thanks
Old 09-30-2016, 12:43 PM   #4 (permalink)
If it is sealed, then the back is virtually the same as the front. But if it was out from the front to fill in the "drop" between the headlights, that would be a bit better.
Old 09-30-2016, 05:46 PM   #5 (permalink)
Thanks yeah it will be pretty sealed behind, so I will go with that thanks.
Old 10-03-2016, 06:29 PM   #6 (permalink)
Got MPG?
The Car - '09 Toyota Corolla CE Enhanced
I have had coroplast behind my grill for a couple of years now. You can't even see that it is there. Still in perfect condition held in place with black zipties.
2013 Honda Civic Si - 2.4L
OEM front to back belly pan from the factory.
Old 10-03-2016, 06:39 PM   #7 (permalink)
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
Putting it on the back is close to equivalent to putting it on the front. Because air can't pass through the grille, a high pressure zone builds up and the air moves around it with very little turbulence.
Old 10-03-2016, 07:04 PM   #8 (permalink)
Thanks everyone I did it on the back, and like that you can't see it.
