Old 08-30-2011, 10:36 PM   #11 (permalink)
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
Someone will have to back me up on this, but "Zero-Pressure Boost" can help the engine with volumetric efficiency at cruise and assist with pumping losses, increasing FE. The question becomes how much energy does it require to spool the turbine to achieve this situation...
Have fun with that new SGII software!
-RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
Old 08-30-2011, 11:31 PM   #12 (permalink)
Driving the TurboWeasel
I have more playing around to do with TPS values since they're a little wonky. It could be this engine uses its DBW throttle to go without an IAC, and keeps the throttle partway open at all times.
It would seem not to take much energy to spool the turbo at cruising speeds. It's a low-power turbo designed to provide power over a wide RPM range, not a high-RPM screamer. It definitely would help with VE since it's still forcing some air into the cylinders. Yeah, it's not actively providing more air. It's still providing more air than a NA engine would have at that RPM.
2012 Chevrolet Cruze Eco 6MT
Old 08-31-2011, 03:44 PM   #13 (permalink)
Ecomodder
Fr3AkAzOiD's Avatar
Cobalt XFE - '08 Chevrolet Cobalt XFE
Team Chevy
90 day: 41.1 mpg (US)
'05 Malibu V6 Tow Vehicle/Track Car - '05 Chevrolet Malibu LS V6
90 day: 23.12 mpg (US)
'08 XFE average for 2013 - '08 Chevrolet Cobalt XFE
Could you get any pics of the aero bits under the car and around the wheels?
Lifetime mpg
2012 mpg
Old 08-31-2011, 06:55 PM   #14 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Fr3AkAzOiD -
+1!
CarloSW2
American Solar Energy Society
Old 08-31-2011, 08:59 PM   #15 (permalink)
Ask, and ye shall receive...
Apologies about the quality.
Front shutter system backside:
Front wheel airdam:
Engine bay undertray:
Underbody tray on driver's side:
Passenger underbody tray. Note front jack point on top of picture:
Rear wheel airdam:
Very dirty rear end:
Looking forward from the rear of the car. Yes, that is the front bumper laying on the ground being modded:
It's okay on the underside for OEM. It still could use some improvement, especially under the rear of the car where nothing was done.
The Following 2 Users Say Thank You to 99LeCouch For This Useful Post:
cfg83 (09-02-2011), Fr3AkAzOiD (09-01-2011)
Old 09-01-2011, 02:05 PM   #16 (permalink)
ncs
RockMagnet - '04 Subaru Impreza wagon WRX
90 day: 26.16 mpg (US)
Ideally, you should run as much boost as possible before the A/F ratio starts going rich. I'm tuned to start going rich at 3psi. It'd be really interesting to see what your more modern engine can do.
It doesn't look like there's enough room, but if you can, put a turbo blanket on, and wrap any unshielded exhaust parts. I went from a factory heat shield, to a blanket + heat shield and it mad a huge difference in under hood temp.
Old 09-01-2011, 02:56 PM   #17 (permalink)
...beats walking...
...FYI the Garrett Model MGT1446MZGL (GM # 55565353) turbocharger unit actually bolts "into" the exhaust manifold, and thus is additionally "cooled" via circulating engine coolant.
...illustration:
http://parts.nalleygmc.com/images/pa...071P03-004.JPG
Old 09-02-2011, 12:24 AM   #18 (permalink)
First tanks: 40 mpg and 42 mpg. Those were on 87 octane. I'm presently trying 93 octane to see if it has a positive effect on fuel economy.
I also got an oil pan heater that's going on shortly. That'll help out some in the winter.
Old 09-02-2011, 11:19 PM   #19 (permalink)
...beats walking...
...believe it or not, but using that oil pan heater religiously will ensure the engine oil is already "warm" for a much quicker engine warm-up time and resulting in better fuel economy.
...just don't FORGET TO UN-PLUG it before you drive off!!!!
Old 09-03-2011, 10:02 PM   #20 (permalink)
Don't worry, I'll make sure! My car's the first in/last out every morning, so there's lots of time to trip over the cord walking out to it!
I also ordered some Nokian R snow tires. They claim LRR and fantastic grip. We'll see.
