Old 05-26-2009, 04:50 PM   #31 (permalink)
Originally Posted by NiHaoMike View Post
It is not recommended to dim halogens since the halogen cycle will not work if the bulb does not warm up enough.
If you decrease bulb temps the filament doesn't last anywhere near as long. The hot filament makes it possible for particulate matter to condense back on the bulb. If its not hot enough the particulates won't melt fast enough, they will just precipitate to the bottom of the bulb.
Its the idea behind HID lights. They fail at low voltage very quickly
2004-2008 Chevy Malibu (Review) RH77 General Efficiency Discussion 11 07-16-2014 05:04 PM
Review: 2008 Chevy Malibu LT (31.3 MPG) RH77 General Efficiency Discussion 12 05-16-2009 10:07 AM
Chevy Volt and GM Get Big Boost From $700B Bailout Vote Today Matt Herring EcoModding Central 15 10-09-2008 05:20 AM
Disabling ONLY DRL's (and not automatic night headlights) in my corolla.... help! blackjackel EcoModding Central 0 07-27-2008 11:47 PM
Chevy S10 vs. Geo Metro vs Prius - electric offroad1994 EcoModding Central 15 07-03-2008 08:01 AM
