Old 11-08-2011, 02:00 PM   #1 (permalink)
EcoMod Proof of Concept
WD40's Avatar
WD-40's Insight - '00 Honda Insight
Gen-1 Insights
90 day: 56.04 mpg (US)
WD-40's Mirage - '15 Mitsubushi Mirage ES
90 day: 46.05 mpg (US)
WD-40's Sonata Hybrid - '17 Hyundai Sonata Hybrid Limited
civic radiator fan amps
Does anyone know how many AMPS a stock civic radiator fan pulls.
I'm looking at getting a Performance Aluminum Fan Shroud Kit from Mishimoto to match my X-Line Performance Aluminum 3 Core Radiator.
The new fan uses 12.25 volts at 5.7 amps = 69 watts.
Hopefully the new one uses less then the stock one to help save gas.
As it is the 3 core rad reduces the amount of time the fan comes on dramatically even with my 95% grill block.
Thanks for any help
Dennis
2000 Insight MT 106K Citrus A/C
Old 11-13-2011, 11:00 PM   #2 (permalink)
Thunder's Avatar
Blew a fuse for my head lights one time swapped out the fan fuse with a 5amp one drove it like that ever since hasn’t blown in 2 years. 91 civic 1.5L don’t know if that helps.
Old 04-24-2014, 10:28 PM   #3 (permalink)
Liberty Lover
j12piprius's Avatar
pris prius - '12 Toyota plug in prius
90 day: 71.09 mpg (US)
3 core radiator
WD40, how do you like the 3 core radiator?
Old 04-25-2014, 06:37 PM   #4 (permalink)
Smaller fans typically use less amps. You could also hook 2 in series and use one as a pusher and puller to reduce power used and move more air.
Water wetter works well too in making the cooling system work better.
