Old 01-25-2013, 01:43 PM   #1 (permalink)
Jelly Bean - '92 Honda Civic VX
90 day: 50.4 mpg (US)
Civic VX lean burn indicator vs vtec light
I recently purchased a 92 civic VX to sit in the stable next to my CRX. I would really like a lean burn indicator light but without the hassle of software, hardware, programming etc.
Is there a direct correspondence between when vtec is activated and lean burn mode? If so i could install a vtec light very easily to show when I am in lean mode or not.
Old 01-25-2013, 02:02 PM   #2 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
If you can use a drill and a welder put a bung on your exhaust, buy a wideband 02 and matched meter.
TADA
Old 01-25-2013, 02:05 PM   #3 (permalink)
TADA
that is an option i have looked at but it is much more expensive than a bulb a wire connection to the vtec wiring.
For my convenience of watching a light turn on and off i wont be spending more than a few bucks. if i cant do this on that budget then i can do without watching a light and just feel for the lean burn
Old 01-25-2013, 02:32 PM   #4 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
I don't know if lean burn can kick in while the V-tec is opening the extra valves, but as far as I know, the extra valves only open when the engine is revved above 2,500 RPM.
Others have made lean burn indicators, I have not.
Old 01-25-2013, 02:49 PM   #5 (permalink)
makes sense. I wasnt sure if vtec opened additional valves or closed them. i know traditionally vtec opens additional valves but since this is vtec-e i thought it may be reversed.
Old 01-25-2013, 02:56 PM   #6 (permalink)
i did a little more research and it seams that the vtec e motor works more like a 12 valve motor (1 intake valve per cylinder) until reaching a certain rpm. it then switches to a 16 valve operation.
So to my initial point, i guess there isnt a direct correlation between vtec and lean burn mode
Old 01-25-2013, 02:58 PM   #7 (permalink)
razor02097's Avatar
Tetanus - '95 Geo Tracker 4WD Base
90 day: 29.43 mpg (US)
300 - '82 Suzuki GS300 L
Last 3: 60.78 mpg (US)
Jeep - '98 Jeep XJ Cherokee Limited
90 day: 12.82 mpg (US)
Here is a link for lean burn indicators...
http://ecomodder.com/forum/showthrea...tor-18913.html
Project Avalon: E bike build
The Following 2 Users Say Thank You to razor02097 For This Useful Post:
MetroMPG (01-25-2013), Ryland (01-25-2013)
