Old 07-17-2015, 05:26 PM   #1 (permalink)
Beginner Hypermiler
Gas Bicycle - '89 Spartamet Bicycle
Last 3: 194.19 mpg (US)
A Swift - '98 Suzuki Swift
90 day: 37.18 mpg (US)
Beater car 2 - '01 Suzuki Swift Summum
90 day: 25.79 mpg (US)
Send a message via MSN to SwiftAnon
Question o2 sensor code but it still works?
I have this strange issue where i get code for my o2 but i still manage to do about 40mpg. is this what causes my mpgs to stay this low? My car is a vw polo from 2000 with 1.4 mpi engine.
error - Album on Imgur
i will be doing a roadtrip soon and i dont want to kill the cat
EDIT: sorry for any mistakes i made. im trying to save as much money as possible and im trying to learn
Old 07-17-2015, 05:32 PM   #2 (permalink)
I do not know. About once a week I get an error code for my oxygen sensor, which I replaced with the correct OEM one because I was receiving the code. I just clear it and the car seems to drive fine.
SwiftAnon (07-17-2015)
Old 07-17-2015, 06:20 PM   #3 (permalink)
Beginner Hypermiler
i clear the code and then it says code pending and later it turns into current fault again.
Old 07-18-2015, 12:48 AM   #4 (permalink)
herp derp Apprentice
Saturn-sold - '99 saturn sc1
Team Saturn
90 day: 28.28 mpg (US)
Yukon - '03 GMC Yukon Denali
90 day: 13.74 mpg (US)
The chart linked to would be more helpful if you could increase the range from 0.43 - 0.434v up to 0.0 - 1.0v.
Does it make it into closed loop, at least at times? Fuel trims less than +/- 10%?
Old 07-18-2015, 05:32 AM   #5 (permalink)
Beginner Hypermiler
i tried it again and it auto ranges. so it is actually stuck between those 2 values. that means it is broken after all. it drives normal, the fuel economy is not horrible and there is not much black stuff in the exhaust.
The car will make a long (400 mile) trip soon.
EDIT: i will check if it goes into closed loop. i will also disconenct the o2 cable and read it with a volt meter.
EDIT 2: the fuel trim is at 0% it never goes into closed loop and the o2 voltage when hot reads 0,4x volt. I order one from aliexpress cus i am cheap basterd
