Old 07-28-2008, 07:36 PM   #1 (permalink)
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 Scion xD RS 1.0 #1633
90 day: 35.45 mpg (US)
Silent Silver Killer - '10 Honda Insight EX
90 day: 51.5 mpg (US)
How to create lift using the underside of your car
The question is simple, Can we create lift by modding the underside of our vehicle? Not enough lift to flip us over, but enough lift that at certain speeds could affect the engine load thereby making our drive more efficient?
At first I was contemplating two ideas, dimpled bellypan, (Mangus effect).
Or some type of wing or spoiler built under the car or near and between the two tires to take advantage of that turbulent air.
Let hear some ideas, or just call me crazy and ignore this thread .. LOL
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
Old 07-28-2008, 07:54 PM   #2 (permalink)
I don't think there is a practical solution for reducing rolling resistance through lift. In order to generate enough lift with some type of wing to make a difference the car will have to be going pretty fast - by which point aerodynamic drag should be a bigger factor than rolling resistance. Hang your car from a streamlined helium blimp and you can maybe have a win at around 10 mph - if there's no wind. Surround your car with a hovercraft skirt and add a big blower and you can reduce rolling resistance to almost nothing, but again, not very practical since you have to use a lot of energy to maintain the pressure under the car.
Old 07-28-2008, 08:04 PM   #3 (permalink)
The Vue - '03 Saturn Vue
90 day: 25.34 mpg (US)
When you generate lift/downforce you also create an equal amount of drag. (Downforce is simply negative lift)
being aerodynamically neutral ( L = 0) is the best. teardrop/non cambered airfoil is best for low drag.
(See attachment, its the NACA 0015 airfoil. Its upper and lower surface are identical. at 0 angle of attack it generates no lift and no drag due to lift. There is still drag but its very low)
Old 07-28-2008, 08:50 PM   #4 (permalink)
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Toyota Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Versa Sedan 1.6 Base
90 day: 41.69 mpg (US)
Why would you want lift? What would it accomplish?
Serious question.
Nissan Versa Aeromods
Old 07-28-2008, 10:27 PM   #5 (permalink)
Serious question.
Less rolling resistance.
Old 07-28-2008, 11:00 PM   #6 (permalink)
Serious question.
When driving I notice that a couple of points off my engine LOD translates into large chunks of FE, so by lifting the nose/front end a hair you could stand to gain quite a bit of FE and not risk disaster.
Old 07-29-2008, 09:24 AM   #7 (permalink)
2k2Prot5 - '02 Mazda Protege5
90 day: 33.82 mpg (US)
I think you're a little confused.
a) lift makes for less traction. More speed = more lift = less traction at highway speeds = bad.
b) lift and downforce both create additional drag. You don't get something from nothing. (it is not equal, however, that depends on a lot of stuff)
c) more air under the car means more air along the turbulant underside
d) a wing in turbulance does nothing. Race cars try to smooth the air before their wing, or hang it up above the roofline for clean air.
Sorry if that sounded like grilling... I think you're just trying to stretch a concept a little too far. Yes, lower RR uses less gas, yes lift will lowing your RR, but it also affects other things... negatively.
Cheers!
Make a belly pan and lower your front bumper. You generate less lift, but you'll have less drag.
Old 07-29-2008, 09:33 AM   #8 (permalink)
Rolling resistance with respect to increases in downforce are very minimal when compared to rolling resistance with respect to speed. You'll definitly end up on the wrong end of the stick should you try to increase lift. I'll see if I can get any graphs or info for you out of Hucho's book for reference.
Old 07-29-2008, 02:12 PM   #9 (permalink)
What? THIS IS MY GOOD CAR
justpassntime's Avatar
The Japillac - '87 Honda Accord LXi Sedan
90 day: 31.77 mpg (US)
Ranchero GT - '73 Ford Ranchero GT
Spaz - '83 Chevy S10 4X4 Tahoe
90 day: 27.53 mpg (US)
Send a message via ICQ to justpassntime
Unlimited Hydroplanes use lift from under the hull to raise them out of the water. They would probably be the best example of what you are trying to achieve, but of course they are not worried about saving fuel. Any type of lift creates drag and may cancel out any gains made in rolling resistance if any.
Honda...the economical, renewable resource.
Old 07-29-2008, 02:52 PM   #10 (permalink)
Since the advent of Mussolini's Autostrada,and Herr Hitler's Autobahn,aerodynamicists have endeavored to eliminate lift altogether from passenger cars.Dr.Alberto Morelli succeeded with his "banana"car of the 1970s.Lift coincides with induced drag,which lowers mpg and can frustrate directional stability at high speed and during gust conditions.
I am not familiar with "Mangus" effect( is that Magnus?),as associated with vehicle undersides.I believe he observed cylindrical artillery shells straying off course,due to the spin induced by rifled cannon barrels.He made the connection,that a spinning cylinder produced lift.That would not be an operating system for a car's underside.If Mangus is the fellow that first made the association with dimples,and golf ball boundary layer separation,this would also be a dead end,as for the Reynold's Numbers which our cars operate at,dimpling would make no difference,as critical roughness would be measured in thousandths of an inch,not inches.
A wing will not work in turbulence.If you block the area between the tires,you increase frontal area,increasing drag.
It's good that your thinking outside the box,however,there already exists a body of empirical scientific data which has already addressed your theoretical inquiry,and no fruit was borne out of investigations.I recommend that you exploit what is already in the bag,then refine the small points from there.Good questions!
I found another advantage to driving an ultra-low Cd car basjoos Aerodynamics 26 08-25-2012 02:15 PM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-20-2012 11:34 PM
Win $100.00 in Free Gas! Design Contest: Ecomod my Ride XFi EcoModding Central 127 02-17-2011 12:07 AM
Active grill block idea holypaulie Aerodynamics 17 10-13-2008 09:31 AM
My First Electric car Experience WaxyChicken The Lounge 8 09-05-2008 08:46 PM
