05-10-2012, 09:37 PM
Cobb and his Phev 2010 Honda Insight
Reason: Adding txt about link.
05-11-2012, 12:57 AM
Location: sw Washington (state), a little north of Vancouver
That is excellant progress! How far is your commute? Many hills?
06 Chev Monte Carlo JG#24tribute car 30mpg 00 Honda Insight 63MPG 98 Buick Park Ave3.8 33MPG 89 Toyota Corolla wag 46MPG so far 81 VW Rabbit diesel pu 50MPG+ 80 Merc 240D stick 30-ish 90 vette 6-speed,29ish 55 Chev 57 Chevw MPG+needhelp07 H ST1300 55MPG 83 H 650 GL 64MPG 19 S dr200 88MPG+Tow K10D Sub 26mpg 70Cuda79Volvo242projectcarsNEVER,NEVER GIVE UP!
PUMP THOSE TIRES UP!
DRIVE IN YOUR SOCKS FOR SENSITIVITY!!!!!!!!!!!!!!!
SLOW DOWN AND SMOOTH UP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
05-11-2012, 08:50 AM
Don't worry, with just a couple more posts you'll be able to add links. We use that as a way to keep down the spam here.
Here's the video:
05-11-2012, 12:41 PM
Nice mileage
Did removing the tail bumper really help ?
05-15-2012, 09:53 PM
05-28-2012, 02:42 AM
2010 Insight upgrades
Originally Posted by Cobb
Ive had my Insight since May of 09 and have continued to get more mpg along the way. Since my Enginer plug in kit adapted from a Prius 2 design and heavy use of "EV" mode I have exceeded 100 mpg for a few miles. I can average 80+ on my commute to work and in the mid 60s with combination stop n go and interstate with lots of traffic on i95.
Ive maxed out the converter and want to explore other ways to improve mpg. Below is a quick walk around of my car in its current configuration. I plan on removing the starter and crap under the hood and bumper that is not needed, add an 84 cell prius pack in parallel to the IMA pack and PHEV kit. Add an exhaust for the IMA and PHEV converter. Use a few prius sticks in place of the starter battery. Maybe hack the CVT to force it in the highest ratio and a relay to cut in the injectors like a FAS switch. Since the insight uses 10.8 to 1 compression I am tempted to try a chemical intercooler and or water injection for mroe mpg once warmmed up.
Here is a list of a few of my mods: Enginer 4 kilowatt PHEV, 3000k 35 watt fogs, Eco bulb highs, 4300k 35 watt low all w/relay kits, DRLs/Rear Wiper removed&rear interior gutted, Sony HU W/front speakers, Tanabe nf springs, 35% tint all around, all LED lamp replacement, 09 fit progress rear sway bar, OEM block heater, full gril block, KN Filter, Honda vent visiors, group 51 battery, home made balancer/grid charger, rain gutter ground effects, full upper grill block, Removed un-necessary crap from rear including bumper cover.
I cant post a link to the video.  Its on youtube titled Honda insight current setup under Mspider12's account.
I too own an EX Insight. I would like more info on the battery upgrade. I traded in my 02 for the 2nd Gen. After several long trips I wondered about modifying the cruise control for an "ECO" mode and drop speed on inclines purposely and just give a little bump up in speed going downhill. I also wanted to "fine tune" the CVT when cruising trying to squeeze out a higher gear for the top end. Stripping extra weight in some areas seems extreme. Has anyone modded the wiper cowling to reduce drag here? A good place for a coverup. Also spotted a MUGEN rear spoiler, due to heat build up I'd rather make it a boat-tail cover.
06-17-2012, 09:55 PM
12-16-2012, 08:46 PM
12-17-2012, 09:23 AM
#9 (permalink)
Adventurist!
Cobb, great numbers out of that car! Have you thought of keeping a fuel log here?
'97 Acura CL 2.2L 5spd
'03 Honda CR-V 2.4L EX 4wd Auto
12-17-2012, 01:21 PM
#10 (permalink)
