Old 01-18-2012, 07:31 AM   #1 (permalink)
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
Compensating for New tyres? Calculating the % out my milometer will be..
Hi,
I've just replaced 2x 205/60/15's with 1.6mm of tread
for 2 new tyres of the same size with appox 9mm of tread.
My BMW takes its milometer feed from the diff, so the increased circumference of the new tyres will change that..
whats the best way to factor in the % difference, or does anyone know a way to calibrate an electronic speedo/milometer?
thanks
My Blog on cars- Fu'Gutty Cars
http://fuguttycars.wordpress.com/
US MPG for my Renault Clio 182
Old 01-18-2012, 02:00 PM   #2 (permalink)
...beats walking...
...does Scotland have "mile-post" markers? If so, simply drive at steady 60 mph (using cruise-control helps) and measure the time (stop watch) between 1 and 2 mile posts.
MPH(x) = 3600 / sec for "1-mile" marker
MPH(X) = 7200 / SEC for "2-mile" marker
...the "correction" factor (%) will be:
% = MPH(x) / 60 mph or % = MPH(X) / 60 mph
Old 01-19-2012, 12:21 PM   #3 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by 320touring View Post
I've just replaced 2x 205/60/15's with 1.6mm of tread for 2 new tyres of the same size with appox 9mm of tread.
You could use a GPS to calibrate the meter.
BMW likely calibrated it with fresh tyres though.
Old 01-19-2012, 02:41 PM   #4 (permalink)
Team m8
cruise control?unfortunately not...
cheers for the formula though
Fair shout- I may try to get my dad's one..
Old 01-21-2012, 03:28 AM   #5 (permalink)
Wanting more for less
D.O.G.'s Avatar
Metric - '94 Honda Magna 250
Motorcycle
90 day: 69.83 mpg (US)
RedCelica - '94 Toyota Celica ZR
90 day: 35.97 mpg (US)
i30 - '12 Hyundai i30 Elite
90 day: 39.84 mpg (US)
i30-22 - '12 Hyundai i30 Elite
90 day: 39.22 mpg (US)
The previous owner of my Mazda Astina (323F in Britain) fitted smaller profile tyres (195/50 15 verses 195/55 15).
I checked the speedo against my GPS on the motorway and it reads about 4.5% fast, as expected.
I checked the odometer against a measured 5 kilometer "speedometer test" sign posted on the motorway and found it to be accurate.....Huh?
I checked the odometer against the GPS driving to work. The GPS said my commute is 51.9km, my odometer said 52.0km, close enough to perfect. Again I say.......Huh?
My point is, don't assume the speedo accuracy reflects the odometer accuracy, as I always did in the past.
If you really have to adjust your speedo, this might help.
Speedo Corrector MkII Kit "Kit Back Catalogue" - Jaycar Electronics
I haven't tried this kit myself, but it sounds OK.
