Go Back   EcoModder Forum > AltModding > Saving@Home
Old 05-03-2011, 11:15 AM   #1 (permalink)
Easter McoModder
SwamiSalami's Avatar
'99 Subaru OLL 2.5L - '99 Subaru Outback Legacy Limited
90 day: 22.57 mpg (US)
Rabbit - '08 VW Rabbit S
90 day: 32.93 mpg (US)
Conserving Toothpaste
Thought I should share some of my thoughts about conserving toothpaste!
The Following 2 Users Say Thank You to SwamiSalami For This Useful Post:
Piwoslaw (05-03-2011), TheMarkofPolo (05-07-2011)
Old 05-03-2011, 04:07 PM   #2 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
I've been doing that for years, only instead of a credit card I slide the tube across the edge of a table or a door frame. Very similar tubes are used for hand cream - when those can't be squeezed any more my Grandma cuts them in half and digs out what's left with her finger. You'd be surprised how much cream is in there! After cutting it open it lasts for another 1-2 weeks!
Dieselbeetle, have you been to Ecorenovator?
Old 05-03-2011, 04:28 PM   #3 (permalink)
Easter McoModder
Oh, nice, that's a good idea, too.
I visited it for the first time today, actually.
Old 05-03-2011, 07:29 PM   #4 (permalink)
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Toyota Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Versa Sedan 1.6 Base
90 day: 41.69 mpg (US)
Try brushing with baking soda.
Nissan Versa Aeromods
Old 05-03-2011, 08:26 PM   #5 (permalink)
Easter McoModder
I've heard of this also. Unfortunately, the majority of drones are unwilling to do so.
Old 05-03-2011, 11:28 PM   #6 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Light humor on my own expense: I'm gonna get false teeth eventually... I'll use less tooth paste than all you Kooky people.
;P
Old 05-04-2011, 12:08 AM   #7 (permalink)
Black Beauty - '13 Hyundai Elantra
Pro tip:
You only need a tiny dab of toothpaste/shampoo/most things of that nature. My stuff lasts a good 3-4 times longer than most people's I know.
The Following User Says Thank You to justjohn For This Useful Post:
Frank Lee (05-08-2011)
Old 05-04-2011, 12:17 AM   #8 (permalink)
Slightly off topic tip: Most soaps do the same thing... Find the cheapest, most effective one, and use it for everything. For example, it's not beyond me to shower and wash my hair with Dawn or Ajax dish soap. I've also used comet on my greasy hands.
Old 05-04-2011, 02:01 AM   #9 (permalink)
aero guerrilla
Piwoslaw's Avatar
My bro-in-law always has a bowl of laundry detergent next to the sink in his workshop to get rid of oil and grease, but using it isn't too good for your skin. I hate expensive soaps, with all their "fresh scents" etc., so I use a cheap soap, and when the bar has been worn down I wet a new bar and press the two together (another trick I learned from my Grandma). Why throw it away?
Old 05-04-2011, 08:03 AM   #10 (permalink)
skyl4rk's Avatar
How to use baking soda to brush teeth:
Put some baking soda in an easily opened bottle, for example an old vitamin bottle.
Wet toothbrush.
Shake a small amount of baking soda from the bottle onto the palm of your hand (pill sized amount)
Use wet toothbrush to pick up baking soda from your hand.
Brush teeth as usual.
Rinse your mouth 3 times with water, otherwise the soda taste will linger.
http://metropioneer.com/index.php?op...=92&Itemid=111
The Following 2 Users Say Thank You to skyl4rk For This Useful Post:
Piwoslaw (05-05-2011), SwamiSalami (05-04-2011)
conservation, conserving toothpaste, saving toothpaste, toothpaste, waste not want not
