Old 06-09-2014, 08:18 AM   #1 (permalink)
paasat05
ecomodding the front splitter
Ok this is my first thread here and I am looking for help to ecomodding my new front splitter. First off I have been on this site for a while but now I have something new to challenge people. I put on a splitter to my passat b5.5 2005 1.9tdi and it is one foot in from either side of the car and am looking to improve it. I don't real do a - b - a testing however I monitor the fuel gauge and every now and again do a test from the reserve light to 24 litres of fuel to reserve light and have got 65mpg imperial but now going hard at it. I will add photos once I get the required posts. any help appreciated
Old 06-09-2014, 08:28 AM   #2 (permalink)
It says that you have six posts, so you should be able to share pictures. We can only help you so much otherwise, although I would think that by only working with the air between the wheels, your are limiting the effectiveness. If you had spats in front of the wheels, directing the air around, that should work better.
Old 06-09-2014, 09:31 AM   #3 (permalink)
paasat05
The following are photos of the front splitter with an attempt to make a blocker which takes air from the front of the car and ducts it to the side so as to decrease the cd of the car. Also the two last photos are before the front splitter when the middle piece could flap out so as at a stop more air can be drawn in.[URL="https://www.dropbox.com/sh/ma4g2t48e8ry813/AAC5eIqO-e-PoWp5Izhhhutga"]
Old 06-09-2014, 10:04 AM   #4 (permalink)
https://www.dropbox.com/sh/ma4g2t48e...PoWp5Izhhhutga
aerohead (06-09-2014)
Old 06-09-2014, 01:18 PM   #5 (permalink)
VW nose/splitter
I suspect that VW has already 'optimized' the Passat's nose,respecting the 16-degree approach angle.(VW 'invented' optimization).
In 1976,the original Rabbit/Golf nose was withing 2% of an 'ideal' aero nose.
If your Passat was within 2% of the ideal,you could not expect more than a 1% improvement in mpg from a nose modification.
To get the 2%,I believe that you'd have to push the lower edge of the nose forward to at least get its face vertical,while maintaining an air dam which was as low as the bottom of the cars belly.
This would aggravate scrubbing on driveways,so the lower lip would have to be flexible.Here's kinda what you'd be looking for
BamZipPow (06-10-2014)
