Old 04-13-2012, 11:42 AM   #1 (permalink)
jackbauer's Avatar
Constant Current Load
Just thought I'd share a little junkbox project. Having been doing battery testing recently I've been looking at electronic loads. Sadly , in the power rating required , they are out of my price range. Looking on the internet I found some designs but they are little mosfet based circuits of a few amps capacity.
So I decided to try and scale one design up using a 150A IGBT and a 100W 0R1 resistor I had lying around. Mounted them to a heatsink and fan and used a bench psu to provide gate voltage. To my surprise it works quite well. Now just have to put together a little op-amp circuit to make it truly constant current. Running at 32A discharging a 4s4p headway 16ah pack today with no problems.
ID:	10659   Click image for larger version
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
The Following 2 Users Say Thank You to jackbauer For This Useful Post:
MPaulHolmes (04-13-2012), thingstodo (04-21-2012)
