Old 07-25-2008, 01:17 AM   #1 (permalink)
converting cx shell to stock vx
just started building my first civic. learning a lot but still know mutch .i bought a d15z1 block w/ p07 head and here is the problem. it came w/ a different intake and throttle body, casting # is p08 hf-2 . cant find any info on the thing but its not the original . looks to be about 64mm . what im looking for is 40mm vx oringinal intake and throttle body . if any one knows of a good link to find part #s or casting #s for different civic stuff it would save me some headaches .also was wondering what the po8 is and whats it is out of .i just got the used wiring harness from a vx from washington state, the salvage place said it was from a fed. model but it has a 4 wire o2 sensor plug and i need the 5wire . well should i drive 4k miles and kick his ass or is easier to run a 5th wire to ecu. whats involved w/ running a new wire and prong
here are the parts ive bought so far let me know if im making a mistake
92 cx shell
d15z1 motor w/p07-1 head , p08 hf-2intake and throttle body
s20 cx tran
vx wiring harness w/ missing map sensor plug only 3 cut wires and 4 prong o2 sensor
looking for p07 ecu
looking for egr control box 92-95 vx
and another trip to the seven junk circles of hell for every clip, mount and bracket known to man
but its good to be turning a wrench
thanks for any input
Glossary Take II SVOboy Forum News & Feedback 50 12-29-2022 08:09 PM
Civic VX & CX Spark Plug Gap flydude1221 EcoModding Central 9 07-01-2012 05:08 PM
Civic VX VIN Info TomO Off-Topic Tech 5 12-07-2010 02:52 PM
VX Info...WARNING: lots of info! TomO Off-Topic Tech 1 01-05-2010 12:39 PM
cx conversion to vx model chris_marsho Off-Topic Tech 0 07-26-2008 11:57 AM
