Old 06-23-2009, 12:10 PM   #11 (permalink)
The Wife's Hot Rod - '09 Pontiac G8 GT
Last 3: 23.22 mpg (US)
Big Outback - '13 Subaru Outback 2.5i
Little Outback - '02 Subaru Impreza Outback Sport
Tire pressures are to be checked cold. Check with your tire manufacturer. They do take that into consideration.
Old 06-23-2009, 09:00 PM   #12 (permalink)
[QUOTE=CapriRacer;111673
Wouldn't it be easier to over inflate by a couple of psi, let the tire cool, then bleed it down?[/QUOTE]
That is what I do.
Fuel the car , pump up the tyres and drive home (less than 1 kilometre) and let the car stand in the garage overnight.
Next morning set the tyre pressures to what I want using my gauge ( and not the one at the petrol station which takes out that variable as well ) with the tyres cold and then do it all again next week.
Pete.
Comparing Warm Air Intakes (WAI) & Cold Air Intakes (CAI) toomuch EcoModding Central 27 11-20-2022 04:24 PM
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-25-2016 11:39 PM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 69 12-27-2014 01:17 PM
Grill block affected milleage mar5ka Aerodynamics 24 08-31-2008 10:17 AM
Moving air intake into the engine compartment? pasadena_commut Aerodynamics 5 07-25-2008 03:24 PM
