Old 09-17-2012, 08:40 AM   #1 (permalink)
The Jetta - '13 Volkswagon Jetta SE
90 day: 37.38 mpg (US)
Coolant question
About a month ago I put a 95% upper grill block on my truck and last week I finally forked out the cash for a ScanGauge. I checked the water coolant temperature with the Gauge after it warms up and it seems high to me. When coasting in neutral it drops to 202 °F and when I'm on the freeway it goes all the way up to 209 °F. Is this normal? I don't have a lower grill block so I think it's getting enough air.
Old 09-17-2012, 09:41 AM   #2 (permalink)
...beats walking...
It depends upon the thermostat temperature, but most newer vehicles *do* use a rather "high" temperature thermostat due to emission standards. Sounds like yours is about 200ºF-210ºF...what does that engine call for--what does the local parts store say it should have? Try asking at an O'Reilly's, Checker, Pep-Boys, etc.
Old 09-17-2012, 10:54 AM   #3 (permalink)
Searching the web for my engine (Magnum 3.7L V6) and what the coolant temperature is bring up no results. My truck is a 2004 so I'm really not sure if that would be classified as *new*. I'm not a mechanic by nearly any means.
The Following User Says Thank You to Specaled For This Useful Post:
buglao (09-18-2012)
Old 09-17-2012, 11:22 AM   #4 (permalink)
That coolant temperature is probably fine. However, you need to see if your radiator fan is running a lot. Wiring a light up to the fan relay is an easy way to tell.
Old 09-17-2012, 11:25 AM   #5 (permalink)
Is there an instruction forum to show how to do that?
Old 09-17-2012, 11:26 AM   #6 (permalink)
Got MPG?
The Car - '09 Toyota Corolla CE Enhanced
How permanent is your block?
The great thing about having the scanguage is that now you can accurately modify your grill block according to your tastes. I would entirely remove it for a baseline reading, then add until the fan starts coming on a little more than normal, then stop. You can tell when the fan comes on by the temperature readings for the most part as well. IMO no amount of grill block is worth endangering the proper operation of the engine and if the fan ends up running more than normal is that extra electrical power cutting into potential savings?
2013 Honda Civic Si - 2.4L
OEM front to back belly pan from the factory.
Old 09-17-2012, 11:31 AM   #7 (permalink)
My grill block is just cholroplast zip tied to the inside of the grill. I couldn't do the outside because of the lack of places to zip tie to.
Old 09-17-2012, 12:24 PM   #8 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
It's a 195 degree thermostat, so the radiator doesn't even come into the picture until then. You're only going 14 degrees over that? Sounds like you're doing fine.
Transmission type Efficiency
Old 09-17-2012, 01:04 PM   #9 (permalink)
Can you source your information? What would be an dangerous temperature?
Old 09-17-2012, 02:02 PM   #10 (permalink)
RobertISaar's Avatar
MC SBX - '95 Chevrolet Monte Carlo LS
Last 3: 29.75 mpg (US)
with an engine designed to run with a 195*F thermostat(and nearly all vehicles since sometime in the 80s have been), i wouldn't worry until you creep above 215 or so.
