Old 09-17-2012, 02:33 PM   #11 (permalink)
The road not so traveled
TheEnemy's Avatar
The Truck - '99 Nissan Frontier xe
90 day: 25.74 mpg (US)
The Ugly Duck - '84 Jeep CJ7 Rock crawler
We have a bunch of 2002 dakota 4X4s at work, even stock they run hot. They all smell of antifreeze no matter what.
Edit: It might be due to the integrated plastic resivoir leaking that they always smell.
The one I drive has a mechanical fan, one thing I noticed its the way the fan shroud is set up there is nowhere for the air to flow as it is ducted right at the front of the engine with only a couple of inches of clearance. Very poorly done IMO.
Old 09-17-2012, 02:41 PM   #12 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
I have a Q45 w/ a V8. The front thempostat opens at 185. The rear at 210.
My scangauge will sit at 195 at idle or park. (even after 20 minutes) while driving it runs from 197 to 213 with it being over 200 most of the time while driving.
According to my Field Service Manual, my 'temp light' is triggered at 230. So 'technically' I'm ok at 229.
with that said, I tend to really pay attention when I get to 220. Especially if the driving conditions will stay the same for more that 30 more minutes. Like driving thru a desert area. Or being in stop n go traffic jam.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 09-17-2012, 03:25 PM   #13 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
My advice is to remove the grill block and see what is normal. Only then will you be able to determine how far you want to press your luck with a grill block. Just remember you want to maintain the same operating engine temp year round to prevent excessive wear.
Old 09-17-2012, 03:46 PM   #14 (permalink)
...beats walking...
A-B-A test time.
Old 09-17-2012, 04:25 PM   #15 (permalink)
The Jetta - '13 Volkswagon Jetta SE
90 day: 37.38 mpg (US)
Being a full time college student living in the dorms means a-b-a tests every 2 weeks lol.
Old 09-17-2012, 05:21 PM   #16 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
as it gets colder you will want a full block on. just watch the temps and see how often the fan comes on I (quick drop in temp from 209 or so down to ~200). keep this minimal and you have your grill block size!
Old 09-17-2012, 05:37 PM   #17 (permalink)
When driving I never notice on the gauge if my fan is one. Either it never turns on or it's always on. My temp drops when I coast in neutral, that's the only time I see it drop. Any ideas?
Old 09-17-2012, 06:05 PM   #18 (permalink)
Wiki Mod
where does the temps stay at?
can you look and see the fan? is it direct powered, belt or electric?
Old 09-17-2012, 06:13 PM   #19 (permalink)
At 60mpg the temp stays at around 206 when its 60ish degree's out. It's belt powered.
Old 09-17-2012, 10:32 PM   #20 (permalink)
90 day: 29.78 mpg (US)
On both my TSX and CBR600 the coolant temps rise whenever I coast in N and plummet once I let the clutch out and the engines comes back up to speed. Everyone else is saying their coolant temps drop while coasting. Strange.
