Old 06-13-2014, 12:40 AM   #1 (permalink)
Smooth hubcaps - Redneck style...
As we all know, smooth hubcaps are just not available. Except, the spun Salt Flat disc caps for $100 a set. They're nice. However, not what I wanted.
So...
This is how I made a set of smooth covers for the Geo for just pennies.
Originally, I covered my existing hubcaps with duct tape.
Functional, yes...
However, butt ugly.
Also, heat and centrifugal force would work their magic slowly over time till it flew off.
It's time to do something different.
Tools and materials
Scissors
Electrical tape
Large black trash bag (heavy duty)
Step 1.
Remove hub caps from car. (duh)
Cut trash bag into squares a few inches larger than the cap.
(1 lg. bag will make six 13"-14" hubcap covers)
Place cut square and hub cap on a flat surface.
Start tucking the plastic under the wire on the cap.
Next, take the electrical tape and start to wrap around the cap in between the wire and the edge of the cap. Try to keep the plastic on the face tight as you slowly work your way around.
It will take several wraps to make it tight and wrinkle free. A extra set of hands would be helpful in getting the wrinkles out. Then, remove the excess plastic from the backside with scissors
(I did mine by myself, can you tell )
Alright, here it is on the car.
Better.
However, plain...
So, I go with my inspiration. The VW XL1.
Some more tape and spray paint.
Tada...
Geo XL1
If you squint real hard, they look a little like the VW.
So far I have put about 2,000 miles on them with minimal problems.
(one or two need a little tightening)
I know they're cheesy...
But, they work and for the cost, they're hard to beat.
The Following 8 Users Say Thank You to redneck For This Useful Post:
101Volts (05-28-2017), Ecky (07-14-2014), Fingie (05-23-2017), MetroMPG (10-23-2014), MPGeo (11-07-2016), NeilBlanchard (06-13-2014), Piwoslaw (01-10-2018), RedDevil (06-13-2014)
Old 06-13-2014, 12:59 AM   #2 (permalink)
Hydrogen > EV
Silver Flea - '05 Honda Insight
90 day: 58.96 mpg (US)
I like it
But all I have are rims
Best Tanks:
Mustang - 54.83 mpg (US) at the Green Grand Prix
Insight - 82.91966 mpg (US) over 818.5 miles.
Old 06-13-2014, 02:20 AM   #3 (permalink)
Originally Posted by UltArc View Post
I like it
Same here! So, next time that I need tires, ask if I can quickly tape garbage bags to them before they mount the tires! Too easy!
Old 06-13-2014, 05:23 AM   #4 (permalink)
cowmeat's Avatar
Princess Carriage - '20 Ford Explorer Limited
Silver - '22 Ford Maverick Hybrid XLT w/tow pkg
Maverick Hybrids
90 day: 41.3 mpg (US)
I have a whole box of those heavy duty contractors bags from Home Depot
Technically, I could wrap my entire car! Then when it breaks down, I can just set it out by the curb on Monday
The Following 3 Users Say Thank You to cowmeat For This Useful Post:
deejaaa (06-14-2014), NickelB NL (10-20-2014), The donkey CRX (06-13-2014)
Old 06-13-2014, 06:44 AM   #5 (permalink)
JasonG's Avatar
05 DMax - '05 Chevrolet 2500HD
90 day: 18.48 mpg (US)
It's a blue XL-1
I can't understand why my MPG's are so low..........
21,000lb, 41' Toy Haulers are rough on FE!
Old 06-13-2014, 06:49 AM   #6 (permalink)
I like it
Another member here "The donkey CRX" made a decent looking wheel cover using vinyl sign lettering material.
(post #130)
http://ecomodder.com/forum/showthrea...-28815-13.html
Old 06-13-2014, 12:50 PM   #7 (permalink)
Here's the "permalink":
http://ecomodder.com/forum/showthrea...tml#post427797
I have an idea on making smooth wheel covers - I'll try to sketch it and post it soon.
Old 06-13-2014, 01:59 PM   #8 (permalink)
jedi_sol's Avatar
2013 STi *SOLD* - '13 Subaru Impreza WRX STi
Subaru
Sports Cars
Team Turbocharged!
90 day: 26.59 mpg (US)
1996 Geo Metro *RETIRED from Ecomodding* - '96 Geo Metro Base
90 day: 58.68 mpg (US)
does the wind cause the "garbage bag" flap even slightly in the wind?
i'm worried that centrifugal and wind forces will eventually cause the garbage bag to tear apart where the garbage bag wraps around the edge of the hubcap.
See the rest of the Sti project log:
http://ecomodder.com/forum/showthrea...log-26612.html
Old 06-13-2014, 03:18 PM   #9 (permalink)
No flapping in the wind.
No centrifugal problems as there is hardly any weight.
I have 2,000 miles on them. No failures...
(they have been 70+ mph)
Even if one were to tear apart, you would only be out of a few pennies.
Just keep a folded up replacement cover and some tape in the car.
10 minutes later your back on the road...
The Following 2 Users Say Thank You to redneck For This Useful Post:
deejaaa (06-14-2014), jedi_sol (06-13-2014)
Old 06-14-2014, 12:11 AM   #10 (permalink)
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
I have used construction plastic sheeting, which I think is the same material as for these garbage bags. It works well for making smooth wheel covers.
However, the plastic will disintegrate over time, due to being exposed to sunlight. Just something to keep in mind.
The Following User Says Thank You to t vago For This Useful Post:
Ford Festiva (08-30-2014)
