Old 11-17-2007, 05:38 PM   #1 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
DIY - Removing Your Radio Antenna
Have you ever hated the look of your radio antenna? Or maybe been bothered by all the aerodynamic drag? I have. Solution: It's gone!
Purpose: To cut down on aerodynamic drag and improve the look of the car.
Time: 15 minutes
Tools:
- Flathead Screwdriver
Supplies:
- Block Off Plate
- Gasket
- Reused Screws
You can get this stuff at the local dealership or online (cheaper) at one of these places.
Here's the antenna. Undo the two screws and yank it out. Make sure to unplug the other end from the stereo.
Awful picture of the antenna on the ground:
The left over hole:
The two parts, I spent about 10 bucks on both:
Put them on with the old screws:
Admire your work:
The CRX no longer looks like an RC car! Quick and easy but it was certainly worth it to me.
Old 03-30-2008, 11:11 PM   #2 (permalink)
anyone have any idea on the .cd difference for a typical car? Or any car....I don't use it ever so a suppose any improvement is worthwhile.
Old 03-30-2008, 11:38 PM   #3 (permalink)
LUVMY02CREW's Avatar
TANK the fifth - '02 Chevrolet S10 Crew Cab 4x4 LS
90 day: 20.44 mpg (US)
This caught my attention....cause my antenna sticks straight up out of the passenger front fender. I know it won't get me any real noticible gains, but I agree with the comment about not looking like an rc toy. I think from what I can picture in my head, I would like the antenna-less look.
Anywhoooooo....I use my radio bunches so I need to keep the antenna's purpose of picking up stations.
So, I was wondering: Is there a way to delete/hide/?shave? the antenna and still get stations????
PS: Did I use the word "shave" correctly? In my mostly bald world that term usually implies a shave cream topped skull with sharp metal being scrapped across it
Old 03-30-2008, 11:44 PM   #4 (permalink)
bhazard's Avatar
2012 Golf TDI - '12 Volkswagen Golf TDI
90 day: 45.51 mpg (US)
Ive also got the big old fashioned antenna sticking out of the front fender, on both cars. Sometimes in the shadow when you're at highway speeds the antenna whips around real fast, kinda like its vibrating in the air, so you know its catching a bit of air.
I just wonder how much mpg improvement you would get from deleting it, or if one of those stubby antennas would help.
'05 Outback XT, 19 mpg
BP-turbo 93 Festiva (long gone)
1/4 mile - 12.50@111.5
Best MPG - 36.8
Old 03-31-2008, 07:52 AM   #5 (permalink)
Eco Noob
Doofus McFancypants's Avatar
Red Rover - '01 Nissan Altima GXE
90 day: 30.07 mpg (US)
My Nissan Altima came with the radio antenna built into the rear defroster.
the "wires" that coil across the class are also serve as the antenna.
Not sure if there is an aftermarket application to reconnect it this way - but might be looking into.
Steve
Steve - AKA Doofus McFancypants
"If there's a new way, I'll be the first in line - But it better work this time"
First Milestone passed - 30 MPG (city) 5/15/08
Best City Tank - 8/31/09- 34.3 MPG (EPA= 20)
Best Highway Tank - 5/20/09 - 36.5 MPG (EPA= 28)
In effort to drive less:
Miles NOT driven in 2009 = 648 (Work from home and Alt Transporatation)
Old 03-31-2008, 01:11 PM   #6 (permalink)
Simple. Hook up the antenna wire to your rear window defogger. It worked great on my bmw.
Old 03-31-2008, 02:43 PM   #7 (permalink)
bhazard's Avatar
What happens when you turn on the rear defrost?
Best MPG - 36.8
Old 03-31-2008, 02:49 PM   #8 (permalink)
Eco Noob
I will have to take a look - I actually think there is a second "loop" back there for my antenna - It may not be same loop in Altima. I have never had any issue with radio in operation and the defroster on. Lived in Upstate NY for 4 years with car before comming down to Atlanta. - never had an issue with it.
Old 03-31-2008, 03:44 PM   #9 (permalink)
I just disconected the rear defogger all together. I need my radio more than the defogger but if its important to you, its possible to make both work.
Old 03-31-2008, 04:13 PM   #10 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
tjts1 -
I think that is what I will try to do. I will disconnect the fuse to the rear defogger and connect the antenna to the "ground side" of the fuse connection on the assumption that "ground side" is going to the rear defogger. That way, I will not risk frying my radio or some other part of the electrical system.
I will then "recover" the hot side of the fuse connection for a different master plan to rule the world (insert diabolical laughter here).
CarloSW2
American Solar Energy Society
