Old 01-24-2015, 02:06 PM   #1 (permalink)
Corvette in GM's tunnel
Here is a link to a video of a Corvette under smoke at the Warren,Michigan big-boy tunnel
[VIDEO] LMR Tests Their Texas Mile Twin Turbo Corvette in GM’s Wind Tunnel
BamZipPow (01-24-2015), Cd (01-24-2015)
Old 01-25-2015, 07:03 PM   #2 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
I went searching for more information on this car, trying to find if LMR ever made good on their promise to produce aeromods for the C6. It looks like they didn't, but I did find a more in-depth article on the car and windtunnel. The captions to the pictures give the most information, including the following:
-"The first mod was to seal off openings in the grille, splitter, and fascia.... This is standard practice in top-speed competition and took a solid 18 counts off the drag coefficient."
-"LMR co-owner, Josh Ledford, crafted up some low-tech wheel discs to flush-cover the 19-inch rims, front and rear. We kinda thought this would be a big step and it was, immediately taking off 12 counts of drag while (or perhaps by) reducing overall downforce."
-"The outside mirrors were then folded in from their normal position seen here. This proved aerodynamically effective."
-"Tom Froling then suggested altering the car’s rake by lowering the nose somewhat. Rather than mess with suspension adjustments (nearly impossible with the car on the platform) the crew simply added sufficient ballast weight under the hood and in the cabin footwells to drop the nose by about 12mm. The effect was rather dramatic, lowering drag by 8 counts, and benefiting downforce to the point where the overall lift coefficient was down to 0.001."
-"By now, we were running out of time, so for one final Hail Mary it was decided to extend the baseplate of the front splitter (by about 1.5 inches at the center and tapering back towards the outer corners). By altering the car’s front/rear aero balance, this proved very effective, taking another 4 counts off drag."
End result: .373 down to .307.
I'll post this in the Crossfire thread, too, as they may be interested in it.
Aerospace Engineer
www.amateuraerodynamics.com
The Following 3 Users Say Thank You to Vman455 For This Useful Post:
aerohead (01-26-2015), mcrews (01-25-2015), Xist (01-28-2015)
Old 01-25-2015, 09:46 PM   #3 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
I know that there is an optimal angle go a front end. Just look at the low rack on the new Mercedes. The front hoofs really are slanted down. When I lowered the front end on the 02 Q45, my highway mpg improved.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 01-27-2015, 05:19 PM   #4 (permalink)
C6 mirrors (10% of drag ?)
I took everything accounted for in the article and solved for the mirror drag,since it wasn't given.I came up with delta-0.034 ( 10% increase ).
This agrees very well with what the 'Spirit of EcoModder.com' mirrors indicated.
Old 01-27-2015, 09:28 PM   #5 (permalink)
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
there was so much 'money' left on the table at the back. Why not tail that thing properly?
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
Old 01-28-2015, 02:23 PM   #6 (permalink)
It's amazing that the taping of the body work seams and the small hood duct resulted in a reduction of 18 counts of drag. Looks like I'll be pulling out the painters tape when I get home.
Old 01-28-2015, 05:51 PM   #7 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Meaning they sealed off the front end. Taping the body seams has little effect on drag in modern cars
Check out this link and follow it halfway down.
http://www.hotrod.com/how-to/paint-b...-aerodynamics/
You will find this comment :
" Taping seams: Rarely if ever are body-panel seams so large and misaligned that smoothing them with duct tape will make a measurable difference in Cd. We tried it on our Camaro, and it did nothing. "
This was on a 1980 Camaro with body seams big enough to walk through.
Read more: Car Aerodynamics - Hot Rod Magazine
Follow us: @HotRodMagazine on Twitter | HotRodMag on Facebook
The Following User Says Thank You to Cd For This Useful Post:
aerohead (01-28-2015)
