Old 12-29-2007, 06:30 PM   #1 (permalink)
popimp's Avatar
Giant Strawberry - '06 Dodge Grand Caravan SE
90 day: 22.5 mpg (US)
Cost of block heater install
I was thinking about getting a block heater for the van. The price is about $28 for an OEM type. The freeze plug has to be removed and I really don't feel like doing the work. What would be a fair price to pay someone to do it. The dealer said it would be $150 plus the part which I think is way to high. Any thoughts?
Old 12-29-2007, 06:34 PM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Depending on the procedure, I would do it for like 20-50 bucks, prolly. But then I'm not a shop and I don't charge 60 an hour,
Old 12-29-2007, 06:45 PM   #3 (permalink)
popimp's Avatar
How much labor is actually involved?
Old 12-29-2007, 06:56 PM   #4 (permalink)
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
Hardest Part
For me, the hardest part was busting loose that drain plug. Depending on where it's located, there may be some extra labor-time in removing parts to get to it. 7-years of corrosion required a breaker bar and some good tools to get that off.
Then comes the tidal wave of coolant -- make sure you have a big pan to collect it.
Otherwise, installation is simple -- screw-in the heater, run the wire, secure it, and there y'are. Add some coolant and make sure the system is free of air.
All told, it took an evening to get it all together -- not too bad.
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
Old 12-29-2007, 07:24 PM   #5 (permalink)
roflwaffle's Avatar
Camryaro - '92 Toyota Camry LE V6
90 day: 31.12 mpg (US)
Red - '00 Honda Insight
Prius - '05 Toyota Prius
3 - '18 Tesla Model 3
90 day: 152.47 mpg (US)
What about putting the car facing down on an incline to keep some of the coolant from spilling when the freeze plug needs to come out? IIRC, a big screw into the plug itself is good for getting it out w/o having it fall into the coolant passageways.
Old 12-29-2007, 08:38 PM   #6 (permalink)
Who
UnderModded
Pablo - '07 Hyundai Santa Fe AWD
90 day: 23.62 mpg (US)
If you trust the dealer to do good work then that's fine. It really depends on what's involved. Mine was through the roof because they have to remove a frame cross-member on the install. I have no idea why they don't just make them standard in any of the more northern climates. What would it add to the cost of manufacturing? -- maybe $10 at most?
DIY:Install Intermittent Wipers on a VX/CX TomO DIY / How-to 9 03-25-2017 07:47 PM
2003 Toyota Matrix Block Heater Daox EcoModding Central 25 11-03-2012 08:59 AM
DIY - Thermostat Install SVOboy DIY / How-to 2 11-18-2008 03:32 PM
850 watt tank style coolant heater - installed in the Blackfly MetroMPG EcoModding Central 4 11-28-2007 02:10 PM
