Old 05-28-2009, 10:57 PM   #11 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
Update, VMLAB refued to even start on my XP box. I'm about ready to say screw this software emulation testing stuff I think. Unless someone else wants to look at simulavr or something and has a glowing report, I'm not putting any faith in the software only simulators.
Old 06-08-2009, 05:10 AM   #12 (permalink)
I've just finished building a basic test board (uC, rs232, a couple of pots, buttons, leds ...).
For now I'm going to test the serial communication part for the controller on this one. Simple interrupt based transmit only, sending 16bit integers for temperature, pwm and pedal values. There will be no bcd conversion on the controller, I'll just write a dedicated client to receive, convert display and log this data.
Old 06-08-2009, 05:36 AM   #13 (permalink)
dcb
needs more cowbell
dcb's Avatar
Ok, can of worms but ok. Adam was messing around with client stuff here: http://ecomodder.com/forum/showthrea...tml#post106367 , I was rooting for java so anyone could use it, have used rxtx a lot Deploying JAVA with RXTX - Rxtx
just for example, here is a sample java prog that sends a character version of the serial bits to stdout and a hex converted version to stderr (9600, com2)
PHP Code:
import gnu.io.CommPortIdentifier;
import gnu.io.SerialPort;
import java.io.InputStream;
import java.io.OutputStream;
public class
SerialMon {
    static
InputStream input;
    static
OutputStream output;
    static
char[] hexstr = {'0','1','2','3','4','5','6','7','8','9','A','B','C','D','E','F'};
    static
String toHex(int x){
        return
""+hexstr[x/16]+hexstr[x%16];
    public static
void main(String[] argsthrows Exception{
CommPortIdentifier portId CommPortIdentifier.getPortIdentifier(
"COM2");
SerialPort port = (SerialPort)portId.open("serial madness"4000);
input port.getInputStream();
output port.getOutputStream();
port.setSerialPortParams(
9600,
SerialPort.DATABITS_8,
SerialPort.STOPBITS_1,
SerialPort.PARITY_NONE);
        while(
true){
            while (
input.available()>0){
int x input.read();
System.out.print((char)x);
System.err.print(toHex(x));
Old 06-16-2009, 08:38 PM   #14 (permalink)
And here is the result: Trevor has written an awt java app, I modified it a bit to work on my linux (with rxtxcomm), and we have a simple java client for the controller. The nice graphic representation of data to follow ...
L.E.: the current value is fake since my setup has the input pin for the current sensor not connected ... The PWM follows very nicely the change in Throttle
Old 06-16-2009, 09:36 PM   #15 (permalink)
PaulH
MPaulHolmes's Avatar
Awesome! But I think 1701 for current might be a bit optimistic?
kits and boards
Old 06-17-2009, 05:19 AM   #16 (permalink)
well ... It looks like my idea of padding the transmissions with a pair of 0xFF is not going to work in all cases: when i slowly increase the throttle I confuse the algorithm at the moment the throttle value is exactly 0xFF and for a brief moment I get really funny values on my screen
l.e.: solution was simple using 0xFD 0xFF sync sequence should be safe. Actually any non identical 2 values above 0x02 each would work for our values (max 511 for all that we read)
Old 06-17-2009, 02:01 PM   #17 (permalink)
Fixed the bug. Attached is the client program running on windows this time.
I've uploaded the sources, the ready-to-run java ".jar" file and the binary drivers for windows, linux and mac to a subdirectory in svn for other people to use.
Jar file here: /trunk/javaclient/MotorClient.jar - Open ReVolt - Trac
Drivers: /trunk/javaclient/MotorClient/lib - Open ReVolt - Trac
... and the relevant code from the avr:
Code:
Buffer_StoreElement(&txBuffer, (uint8_t) (tmpThrottle >>8)); // Store value for throttleH into ringbuff
Buffer_StoreElement(&txBuffer, (uint8_t) tmpThrottle); // Store value for throttleL into ringbuff
Buffer_StoreElement(&txBuffer, (uint8_t) (tmpCurrent >>8)); // Store value for currentH into ringbuff
Buffer_StoreElement(&txBuffer, (uint8_t) tmpCurrent); // Store value for currentL into ringbuff
Buffer_StoreElement(&txBuffer, (uint8_t) (pwmDuty >>8)); // Store value for currentH into ringbuff
Buffer_StoreElement(&txBuffer, (uint8_t) pwmDuty); // Store value for currentL into ringbuff
Buffer_StoreElement(&txBuffer, (uint8_t) 0xF0); // Sync Byte
Buffer_StoreElement(&txBuffer, (uint8_t) 0xFF); // Sync Byte
//enable USART "TX buffer empty" interrupt
UCSRB |= _BV(UDRIE);
Old 06-20-2009, 10:59 AM   #18 (permalink)
Trevor is making good progress ... He sent me the version with graphic representation of the loged values and it works really nice!
_____________________________________________
http://svn.fastdigitech.ro/trac/openrevolt/browser
http://svn.fastdigitech.ro/repos/openrevolt
Old 06-20-2009, 11:50 AM   #19 (permalink)
Java client
Charlie pointed out a few other things to clean this up a little.
my task list
-adjustable scaling on the chart (or fixed from 0 - 512)
-writing to csv
-change the end of packet suffix to FF F0 ( your code above looks like F0FF?)
the graphing is working pretty well, glitches every once in a while....not sure why, if its because of my pic or a software bug.
Old 06-20-2009, 02:19 PM   #20 (permalink)
Correct! 0xF0 0xFF. Already changed that in the java code in the svn.
Paul & Sabrina's cheap DIY 144v motor controller MPaulHolmes Open ReVolt: open source DC motor controller 7381 08-02-2023 10:55 PM
Ben Nelson's Electro-Metro Build thread bennelson Fossil Fuel Free 1499 12-22-2019 07:24 PM
Longtime Lurker Looking for Miles ZX40 Electric Micro van mods & information rmay635703 Fossil Fuel Free 49 07-06-2014 10:27 PM
Hybrid PWM/Contactor controller turbo-boost bennelson Fossil Fuel Free 24 05-12-2011 10:26 AM
Fun with Voltage Controller Heatsinks Dradus Fossil Fuel Free 14 05-02-2008 03:16 PM
