Old 06-20-2009, 08:01 PM   #21 (permalink)
PaulH
MPaulHolmes's Avatar
You guys are awesome! Keep it up!
kits and boards
Old 06-21-2009, 11:17 PM   #22 (permalink)
Is the PWM duty going to be returned with a value of 0 to 100 ......percent duty cycle
no point having the scale go to 512 if its only ever going to go to 100...
Cheers,
Trevor
Old 06-22-2009, 12:20 AM   #23 (permalink)
PaulH
Right now the pwm duty has a resolution of 512, but the accuracy is only maybe 7 or 8 bits. I'm planning on increasing the accuracy (since there's now time because there are no while(); stuff during A/D conversions. So, if the resolution is greater than 8 bits, will that be a problem with the software that's assuming 8 bits? Or will there be a conversion to 8 bit, or should I cut it out with the 9 bit resolution stuff?
kits and boards
Old 06-22-2009, 05:49 AM   #24 (permalink)
The software now is sending/receiving 16 bit values. Values up to 15 bit will work since we need a sync bit. With the sync values we are using now (0xF0) you can go up to 12bit before we need to change that
_____________________________________________
http://svn.fastdigitech.ro/trac/openrevolt/browser
http://svn.fastdigitech.ro/repos/openrevolt
Old 06-22-2009, 06:13 AM   #25 (permalink)
ah, ok, I understand.
ya the client is just the slave......it can do anything you need.
that being said do we want to translate that into a % duty cycle on the client side?
Old 06-22-2009, 10:42 PM   #26 (permalink)
Awesome work guys! Keep it up.
I will be watching this with interest, could be very interesting to have this running on board.
Old 06-22-2009, 11:25 PM   #27 (permalink)
Writing to CSV
I think I have a few more things nailed down.
-write to file is done.....writes to csv (Comma delimited)
-Auto Scale or fixed 0-512
-Cleaned some things up a little
-add some more comments.
-Changed suffix to match Charlies change...
Write to File, eg. Graph in Excel
Cheers,
Trevor
Paul & Sabrina's cheap DIY 144v motor controller MPaulHolmes Open ReVolt: open source DC motor controller 7381 08-02-2023 10:55 PM
Ben Nelson's Electro-Metro Build thread bennelson Fossil Fuel Free 1499 12-22-2019 07:24 PM
Longtime Lurker Looking for Miles ZX40 Electric Micro van mods & information rmay635703 Fossil Fuel Free 49 07-06-2014 10:27 PM
Hybrid PWM/Contactor controller turbo-boost bennelson Fossil Fuel Free 24 05-12-2011 10:26 AM
Fun with Voltage Controller Heatsinks Dradus Fossil Fuel Free 14 05-02-2008 03:16 PM
