Old 10-08-2013, 01:26 AM   #1 (permalink)
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.92 mpg (US)
Engine Position and Torque Output
When working on my car, often I use my ratchet wrench, but I need more torque so I elongate the handle with a pipe or longer wrench. I'm using that thought process through this question:
Can the placement of the engine and drive wheels change the torque output? So if the engine is in the front and the car is RWD, would it have more torque then a front engine, FWD car of the same hardware, everything else equal?
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
Old 10-08-2013, 01:32 AM   #2 (permalink)
No lever arm advantage if the shaft is rotating along its axis rather than around a point.
