Engine Position and Torque Output
When working on my car, often I use my ratchet wrench, but I need more torque so I elongate the handle with a pipe or longer wrench. I'm using that thought process through this question:
Can the placement of the engine and drive wheels change the torque output? So if the engine is in the front and the car is RWD, would it have more torque then a front engine, FWD car of the same hardware, everything else equal?
Don't forget to like our Facebook page!
Best EM Quotes:
Originally Posted by aerohead
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
