View Poll Results: If i could get XL1 lrr tires, what should i choose?
115mm front, 145mm rear 0 0%
145mm rear, 115mm front, 0 0%
145mm all around 2 20.00%
115mm all around 8 80.00%
That is a crazy idea! 0 0%
Voters: 10. You may not vote on this poll
Old 06-12-2014, 05:29 PM   #1 (permalink)
If i could get VW XL1 tires:(115/80 R15 front, 145/55 R16 rear)
The VW XL1 has low rolling resistance Michelin tires (115/80 R15 front, 145/55 R16 rear). If i could get a hold of some, Should i do:
A, 115mm front, 145mm back,
B, 145mm front, 115mm back,
C, 145mm all around,
D, 115mm all around,
E, I am crazy,
Please consider that my car is front wheel drive, but the XL1 is rear wheel drive, so it has thicker tires at the rear. If i were to swap thicker tires at the front drive wheels, and narrow at the rear, wouldn't that be unstable in the snow? They say to put newer tires with the most tread at the rear so you don't lose the back in the snow.
I would suppose 145mm tires all around would suffice, but a part of me wants 115mm tires all around for maximum efficiency! Would that be a wise choice?
My car is about 1,930 lbs, the XL1 is 1753 lbs, for a 177 lb difference. The XL1 has lightweight magnesium wheels—the fronts weighing 6.97 lb, the rear 8.18 lb. I would use steel spare tires from a Mini cooper and other unidentified cars. The change in overall diameter from my stock tires should be the same.
I try to be helpful. I'm not an expert.
Old 06-12-2014, 05:53 PM   #2 (permalink)
90 day: 30.18 mpg (US)
If you did not need to use steel rims, you would be that much closer to the weight of the XL1, although the tires would definitely help.
Old 06-12-2014, 05:53 PM   #3 (permalink)
Hydrogen > EV
Silver Flea - '05 Honda Insight
90 day: 58.96 mpg (US)
C'mon sheepdog! 115 all around
Best Tanks:
Mustang - 54.83 mpg (US) at the Green Grand Prix
Insight - 82.91966 mpg (US) over 818.5 miles.
Old 10-31-2014, 07:38 AM   #4 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
Today visited local VW dealer and they again checked if VW XL1 wheels and tires are found on their parts catalogue and they were. However they were not able to get prices as that model is not sold to Finland.
So if somebody could go in germany dealer and find out what those would cost, I would appreciate much.
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
Old 10-31-2014, 01:53 PM   #5 (permalink)
darcane's Avatar
Too bad polls don't allow for two answers... D. and E. is the obvious choice.
As long as you're talking crazy, maybe look at wheels intended for drag racing. Weld Magnum Import skinnies run just over 8lbs... 15x3.5 would be a perfect fit to those tires.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
Old 10-31-2014, 05:56 PM   #6 (permalink)
What you need are Mazda RX-7 or RX-8 space saver alloy wheels
Black Lupo 3L 1.2tdi Manual converted the windsurfing bus!
Kermit the Lupo 3L 1.2 Tdi with a current mpg record of 114mpg (imperial) Now sold
G1 JDM Insight I hate the ride but love the quirkiness
Old 10-31-2014, 06:19 PM   #7 (permalink)
Weld Magnum Import 15x3.5, 4x100 One Piece Skinnies - Polished or Black
That price is for one...
Old 10-31-2014, 06:23 PM   #8 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
Or try these guys. They'll even weld on the Dzus mounts so you can fit a real set of moonies.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
Old 10-31-2014, 07:48 PM   #9 (permalink)
List price: $588.00
Our price: $535.00
Old 11-01-2014, 04:47 AM   #10 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
Got the prices for XL1 wheels and tires .
4 tires: ~ 9200€. 4 rims: 6400€. Without shipping
Who is first to order
