Old 06-03-2008, 02:45 PM   #1 (permalink)
gamer_jim's Avatar
Reds' Bucket Mobile - '01 Chevrolet Cavalier 4 Door Sedan
90 day: 33.46 mpg (US)
DRL Kill Switch?
I found a good tutorial online to disable the DRL's on my '01 Cavalier.
http://www.j-body.org/forums/read.ph...8&t=326113&p=1
I'm not that good with electronics so I hope this isn't a stupid idea. If I purchase a switch at Radio Shack, can I wire that so that I can switch the DRL's on and off, instead of doing a permanent off solution?
Old 06-03-2008, 04:05 PM   #2 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
gamer_jim -
I just bent a pin on a relay for my car's lights (it's a Saturn-only mod). I keep a spare fuse in my trunk if I want/need to switch it back.
CarloSW2
American Solar Energy Society
Old 06-04-2008, 11:25 AM   #3 (permalink)
90 day: 51.82 mpg (US)
I also added a switch on my DRLs, but I DO switch them back on, during the day, in certain types of driving.
Old 06-04-2008, 01:58 PM   #4 (permalink)
gamer_jim's Avatar
Question about what type of switch to use.
I don't know electronics that well so please forgive the ignorance.
I read this about switches:
http://www.kpsec.freeuk.com/components/switch.htm
and from what I understand I need a SPDT, Single Pole Double Throw switch, is that correct? Because I want to either continue the blue wire circuit or switch it to the ground (if you followed the tutorial I linked in my OP).
I found this switch at Radio Shack that I really like:
http://www.radioshack.com/product/in...entPage=search
but it is listed as a SPST. Will this not work for me? I do not like any of the SPST switches listed on RS's website. I'm trying to stay way from the mad-scientist look in my car as this may become my wife's primary car in the future.
Recommend any other places to buy or different switches?
Old 06-04-2008, 09:33 PM   #5 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
Mine goes off with the parking brake engaged, so I did a "Redneck Fix" and grounded the parking brake wire so the DRL's are off but I will never know if my brakes are gone
GeoMetroforum.com - got mpg?
Old 06-04-2008, 09:43 PM   #6 (permalink)
That's what I did too, Johnny. Except I put a switch in between the wire & ground. The parking brake light on the dash reminds me the DRLs are out.
Old 06-04-2008, 10:10 PM   #7 (permalink)
Pushrod - '02 Chevrolet Cavalier
This trick works only on 20th century Cavaliers. Newer ones will switch the DRLs back on if you exceed 5mph.
You need a switch that has 3 pins per pole.
Old 06-05-2008, 09:40 AM   #8 (permalink)
gamer_jim's Avatar
Is that was is referred to as a SPDT switch?
Old 06-05-2008, 10:12 AM   #9 (permalink)
Yes, and within that category, there are two and three position switches. Two positions simply switch between the two outer pins while three position switches have a center position that lets the center connection float. You want the former.
Kill switch for 88-95 Honda Civic/CRX/DelSol AndrewJ DIY / How-to 40 06-18-2012 03:13 AM
Geo Metro Kill Switch Idea? HotRod EcoModding Central 5 01-27-2011 06:13 PM
Normally closed momentary switch. getnpsi DIY / How-to 21 08-29-2009 11:29 AM
I'm curious about a "nitrous" style engine kill button Volones DIY / How-to 38 05-22-2008 12:12 AM
Winter mod - heater blower integrated with engine kill switch MetroMPG EcoModding Central 3 12-31-2007 10:31 PM
