Old 03-16-2008, 09:24 PM   #11 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
I can comment on the noise level being reduced when I briefly had a full belly pan on my Firefly. I recall krousdb saying the same thing - he's added full pans to 3 of his cars so far.
Old 03-16-2008, 09:44 PM   #12 (permalink)
H4MM3R's Avatar
Nice work on the REX!
Old 03-16-2008, 09:54 PM   #13 (permalink)
H4MM3R's Avatar
Otto ~Welcome to the community.
Old 03-16-2008, 11:01 PM   #14 (permalink)
bestmapman's Avatar
Very nice. How much would you charge to do my Prius?
Old 03-17-2008, 12:14 AM   #15 (permalink)
How much quieter did it get?
Smoother flow and greater aero efficiency would make less wind noise under the car, less engine noise since less throttle is needed for propulsion, and the coroplast acting as an insulator/reflector of noise away from the car body. In theory.
Can you hazard a guess as to decibel reduction?
How durable and fireproof has the coroplast proven to be? In other words, what shape is it in after a couple of years of driving? Or, am I gonna have to shinny under the car constantly to mess with this stuff?
Old 03-17-2008, 12:50 AM   #16 (permalink)
Ecomod noob
zjrog's Avatar
ZJ - '95 Jeep Grand Cherokee Laredo Upcountry
90 day: 20.57 mpg (US)
Neon - '03 Dodge Neon SE
90 day: 33.46 mpg (US)
S'Crew - '02 Ford F150 Supercrew XLT
90 day: 16.4 mpg (US)
Ranger - '90 Ford Ranger
Last 3: 28.02 mpg (US)
Not the Jeep - '03 Dodge Neon SE
90 day: 34.11 mpg (US)
Hmmm, need a cheap source of coroplast locally. Somehow, I think Sam's Club would get upset if I stole the big sheets from their shopping cart garages...
I have the added challenge of trying to smooth the bottom of a Jeep with a shovel for a transmission skidplate.
When it comes to Heroes, RENEGADES are mine!
Old 03-17-2008, 10:31 AM   #17 (permalink)
Otto - can't hazard a guess on decibel reduction. Though all your points are valid. The belly pan was only on my car temporarily. For safety, I used a mix of aluminum flashing (near the exhaust) and coroplast.
Old 03-17-2008, 03:58 PM   #18 (permalink)
basjoos's Avatar
Aerocivic - '92 Honda Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Honda Civic CX
90 day: 55.14 mpg (US)
Camryglide - '20 Toyota Camry hybrid LE
90 day: 62.77 mpg (US)
My coroplast underpanelling has been in place since May 2006 with no deteriation problems. Since its made of thin polyethylene, it should last well in locations like the underside that don't get a lot of direct sun, but will get brittle after a few years exposure to direct sun. I've replaced all of the coroplast on the top and sides of my car with aluminum sheet, but left the underpanel, side skirts, and front wheel spoiler in coroplast for its flexibility when hitting road debris.
aerocivic.com
The Following User Says Thank You to basjoos For This Useful Post:
BabyDiesel (05-15-2015)
Old 03-19-2008, 10:40 AM   #19 (permalink)
Eco-Nerd
Props on the Coroplast! I am going to experiment with it until I achieve a final shape. That will be my pattern for thin sheet aluminum.
With all of those projects of yours, a good set of ramps and a 2-ton engine hoist might be a wise $200 investment. Much cheaper that the ER.
I saw the 3-wheel motorcycle on your website. Great idea! Is it a 2-seater? What front suspension did you use?
THX,
Cowspots
Old 06-08-2008, 03:40 PM   #20 (permalink)
88CRX - '88 Honda CRX Standard DX
90 day: 32.74 mpg (US)
IS250 - '07 Lexus IS250
90 day: 25.79 mpg (US)
RX300 - '00 Lexus RX300
90 day: 18.38 mpg (US)
That is exactly what i wanna do to mine.
What mpg change did you get?
Any issues with it so far?
Thanks!
Metro undertray / belly pan MetroMPG Aerodynamics 47 03-13-2014 05:13 PM
Belly pan or vortex generators? edbso Aerodynamics 125 02-22-2011 12:50 PM
