Old 12-04-2007, 03:51 PM   #1 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
[CRXMPG FAQ] SuperMID and 1990 Toyota Truck
Recently got this question on www.crxmpg.com, my site:
I am looking for instrumentation of measure current mpg for a 1990 Toyota truck (1-ton pickup with EFI V-6). Read your post on the SuperMid and wondering if it would be applicable. As a Prius owner really getting hooked on the instantaneous feedback and would really like to get as much "scangauge-like" functionality into my hobby vehicle.
Any info will be appreciated.
Thanks
Thanks for the question,
If you have EFI, it's likely possible that you can use the superMID with the truck. However, there may be an issue with the size of the injectors as the range is limited (I believe) within the MID's programming. Also, is this TBI or individual injectors? If you have some more information I would gladly pass on your information/invite Yoshi here to comment on your question.
Thanks again!
