Old 05-14-2016, 07:54 AM   #1 (permalink)
Cylinder Deactivation, Stand alone managment on GM D.O.D. motors?
I'm planning on swapping in a newer (2008ish) GM V8 engine into an older car. Many of the engines I'm looking at have the ability to shut down 4 of the cylinders (displacement on demand/active fuel management, DOD/AFM). Just wondering if it's possible/has anyone managed to take advantage of that feature using a stand alone engine control system such as megasquirt or the like. The motor will be mated to a manual transmission and installed in a vehicle that weighs 3000lbs.
Thanks
Old 05-14-2016, 09:28 AM   #2 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
I have heard that technology creates longevity issues. I imagine that if the gearing is appropriate, the additional gains from dod would be minimal.
Old 05-14-2016, 11:46 AM   #3 (permalink)
Dark Egg - '12 VW Touraeg
It works well on my 2008 5.7 Chrysler with 150,000 miles on it. I just wish you could lock it in. The slightest increase in throttle kicks it off. I want it to stay on up until about 1/2 or 3/4 throttle. The aftermarket mpg monitors can't seem to figure out correct readings but the on board long term mpg gauge seems to keep accurate numbers. It's not a miracle but it certainly increases mpg yet still has plenty of power when you want it.
Old 05-16-2016, 11:39 PM   #4 (permalink)
5 pin sensor
Zippy - '96 Honda Civic Hx
90 day: 40.77 mpg (US)
Boring - '11 Ford Fusion Sel
90 day: 21.88 mpg (US)
Correct. It is a known issue on gms that can cause lifter failure, camshaft failure, or even engine failure in extreme cases. Dod should be avoided on gm vehicles
Current: 1997 civic lx
Past: 1998hx/1996hx/1997lx/1997hx Cali/1997hx
OG lean burn member
My civic thread
