Old 12-28-2009, 07:30 PM   #1 (permalink)
1.4 TDI - '03 Seat Ibiza
90 day: 49.68 mpg (US)
Kinda ScanGauge w/o OBD
Hi there!
Is there any kinda equipment like scangauge for cars without OBD? No electronics at all.
The only one I know is the vacum meter.
Thanks!
Old 12-28-2009, 07:44 PM   #2 (permalink)
...beats walking...
...how far back year-wise are you talking about?
...if it's got electronic fuel injection of any sort (throttle body, manifold, etc.) then possibly the MPGuino is usable?
...if it's straight carbureted, you might have problems.
Old 12-28-2009, 08:14 PM   #3 (permalink)
It's an old diesel engine from 1992 a ford fiesta 1.8D, I think the vacuum is the best solution right?
Old 12-28-2009, 08:16 PM   #4 (permalink)
Does the engine have a throttle? If not, a vacuum is pretty useless.
Old 12-28-2009, 08:30 PM   #5 (permalink)
...beats walking...
...as Daox states, a vacuum gauge is only usable if the engine is "throttled," since diesel engines are un-throttled with engine speed being controlled by injector fuel volume.
Old 12-29-2009, 06:24 AM   #6 (permalink)
But you can plug a vacuum meter on the brake vacuum lines right?
Won't it give the right data?
Old 12-29-2009, 02:46 PM   #7 (permalink)
...beats walking...
...yes, you could connect it there, but...
...no, because THAT vacuum I believe is a mechanically 'pumped' vacuum and not the diesels' manifold vacuum which is basically atmospheric pressure, ie: NO vacuum.
...you really want to measure how hard (or not) the engine is "working" not the barometric atmospheric pressure that tells you the altitude.
Old 12-29-2009, 05:43 PM   #8 (permalink)
But i fitted on a gasoline Seat Ibiza like i said and was working! It connects to the intake manifold! Right?
So can do nothing to scan anyway the engine?
Old 12-29-2009, 06:01 PM   #9 (permalink)
Old 12-30-2009, 10:45 AM   #10 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
A gasoline engine was vacuum in the manifold, that's just the way it works. This vacuum can later be used for brakes, etc. In a diesel there is no vacuum, so the brake assist has to be generated by an external pump powered by the engine. A diesel would work just fine without the vacuum pump, in fact it would have that much less load on its accessory belt or camshaft.
If your diesel has a turbo, then you can monitor the intake air pressure. It's not much, but always something.
OBD MPGuino gauge jmonroe OpenGauge / MPGuino FE computer 855 03-16-2018 08:47 PM
Scangauge II vs cruise control rjacob Instrumentation 10 06-02-2011 02:36 PM
Dealer says ScanGauge ruined my PCM and I can't use ScanGauge anymore Markmysite EcoModding Central 55 05-06-2010 06:31 AM
Scangauge and Partial Fills trikkonceptz Instrumentation 7 10-15-2009 12:10 AM
Scangauge 1 - Some help please! jdubbs_scort Instrumentation 6 06-17-2008 03:26 PM
