Old 08-04-2013, 11:29 PM   #1 (permalink)
Coasting in the Carolinas
wolydotmatrix's Avatar
Blue - '94 Honda Civic DX
90 day: 47.49 mpg (US)
Stage 2 Aero mod
Proper Prior Planning Prevents Piss Poor Performance.
Old 08-05-2013, 01:07 PM   #2 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Looks like a Bonneville car .
Nice !
The Following User Says Thank You to Cd For This Useful Post:
wolydotmatrix (08-05-2013)
Old 08-05-2013, 01:45 PM   #3 (permalink)
Thanks,
I have been toying with the idea of a reverse nozzle design to increase the air saturation of the radiator. In my head 9 transmission funnels stacked 3 by 3 with the big end at the radiator. Utilizing the current 9 holes in the Lexan to direct and or concentrate the air to the radiator via the funnels. There are a couple of un answered questions I have. What is the optimum angle for the cone so the does not detach the air internally or would this matter less because the fan would be pulling the air through. Would more holes or larger holes be recomended for the inlet.
Initial testing has proven to be worth the mod. Largest increases were found at steady cruise above 45mph. 3-5mpg increse at steady cruise was a nice result.
Views and opinions are welcome??
Old 08-05-2013, 02:24 PM   #4 (permalink)
jedi_sol's Avatar
2013 STi *SOLD* - '13 Subaru Impreza WRX STi
Subaru
Sports Cars
Team Turbocharged!
90 day: 26.59 mpg (US)
1996 Geo Metro *RETIRED from Ecomodding* - '96 Geo Metro Base
90 day: 58.68 mpg (US)
i think your overthinking it (or i may be oversimplifying my thoughts).
If your car starts to overheat...cut a bigger hole?
on my del sol, full lower grill block, i only had a 5" x 3" rectangular hole in front of the radiator...no funnels or anything. I've never had overheating problems.
See the rest of the Sti project log:
http://ecomodder.com/forum/showthrea...log-26612.html
Old 08-05-2013, 06:11 PM   #5 (permalink)
pinching off your flow
Originally Posted by wolydotmatrix View Post
I would recommend you search GOOGLE Images for 'vena contracta 'n see if you wouldn't want to do one,single,larger,properly radiused opening to bring the air in.In actuality the available opening for the air to enter is much smaller than what the eye can see.
Those square-edged holes have the highest drag measurable and are working against you.
Old 08-05-2013, 08:29 PM   #6 (permalink)
Hmmm!
Makes sense
Will have to look into this.
