On my first car (a 77 Cutlass) the dash lights failed one day and I just couldn't find the root cause in my early years of troubleshooting. It was no big deal until I couldn't tell how fast I was going at night and had to keep turning on the dome light to check. The solution was to buy a small bulb, mount it outside of the speedo pod, and wired it into the cruise control on/off switch (which didn't work anyway). It was a cool little light with that green "office lamp" glass on the back.
I often thought that this would be an easy LED setup on vehicle setups with a minimalist bulb philosophy (if you can minimize glare off of the panel cover and to shield direct bulb view to the driver).
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
![](http://ecomodder.com/forum/fe-graphs/sig17a.png) _
![](http://ecomodder.com/forum/fe-graphs/sig3482a.png) _
