Old 09-22-2020, 02:31 AM   #1 (permalink)
How to do pics of tuft testing
One thing I really notice is that very few pics of tuft testing are posted here. As a zero cost way of seeing where there is attached and separated airflow - and also airflow direction - tuft testing is brilliant.
I like to use still image cameras for this (ie as opposed to a video camera), taking a sequence of photos and then picking the best single one that is indicative of the tuft pattern. Then I usually crop it a lot.
Photographing from the side of the road when the car passes you at ~60 km/h (35 mph) is usually fine. (Probably, you can do it in the street in which you live!)
To do this type of photography, I think that you need a camera that has:
  • a fast shutter response, ie it takes the pic the instant you press the button (most dig cameras these days)
  • the ability to set the required high shutter speed (most good consumer cameras and all 'prosumer' cameras)
  • the ability to do a sequence of shots rapidly, one after the other (varies lot between cameras - look for burst mode of, say, 8-10 shots)
  • a telephoto lens focal length that retains good resolution (again, most good consumer cameras and all 'prosumer' cameras, but be wary of digital zooms)
So, a sequence of pics as the car drives by me:
And then after selecting and cropping:
Final shot:
  • Nikon D300
  • Focal length 195mm (35mm equivalent)
  • F9 aperture at 1/500th of a second shutter speed
  • +0.3 stop exposure compensation
(This pic is showing the airflow pattern without Edgarwits front external air curtains)
And here is another, literally taken in the middle of suburbia (the driver was braking for the culdesac at the end of the street - note neighbour's post box!):
The Following 2 Users Say Thank You to JulianEdgar For This Useful Post:
COcyclist (10-23-2020), Gasoline Fumes (09-22-2020)
Old 09-22-2020, 02:59 AM   #2 (permalink)
An industry standard for testing is the 100ft circle (usually for G-forces).
With a camera on tripod and operator at the center you could record crosswind conditions efficiently.
Old 09-22-2020, 03:20 AM   #3 (permalink)
I have done extensive amounts of skid pan testing, including at car manufacturer's proving grounds, on test facilities, and on my own circles (chalked on roundabouts for HPVs).
I do not think this is a good guide to crosswinds, as the air yaw angle is constantly changing - and the 'crosswind' component is relatively small.
On my 'home' skid pad:
(My first recumbent trike: it met the skidpan criterion but it was waaay too heavy.)
And my Lexus on the skid pan
Old 09-22-2020, 06:43 AM   #4 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
I did some tuft testing with my ugly old Honda Civic Wagon. Lousy photos, didn't get any help!
Hood, windshield and roof looked good.
Behind the front wheel:
It looked like air was going under the side skirt:
Side mirror:
Side mirror removed:
I was so surprised by the air moving upwards behind the A pillar that I added more tufts!
ID:	29168   Click image for larger version
ID:	29169   Click image for larger version
ID:	29170   Click image for larger version
ID:	29171   Click image for larger version
ID:	29173   Click image for larger version
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
Old 09-22-2020, 12:15 PM   #5 (permalink)
マット
M_a_t_t's Avatar
The Van - '95 Chevy Astro Cl V8 Swapped
Team Chevy
90 day: 7.84 mpg (US)
The new bike - '17 Kawasaki Versys X 300 abs
Motorcycle
90 day: 71.94 mpg (US)
The Mercury - '95 Mercury Tracer Trio
Team Ford
90 day: 34.35 mpg (US)
Toyota - '22 Toyota Corolla Hatchback
90 day: 40.11 mpg (US)
I have the same problem. I think I've convinced my Mother to drive my car and then I can try to take pictures from the side of the road or follow in her car and try to take pictures or atleast observe them and take notes.
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
Old 09-22-2020, 05:20 PM   #6 (permalink)
Yes, very seldom any problem in these areas on any car of the last 30 years
Looks excellent with smooth wheel cover
Often the case - airflow is travelling towards the low pressure area under the car.
Side mirror:
Flow on the door window is better with the mirror present! Mirror present: main door glass flow separation only behind mirror support. Mirror not present: main door glass separation more prevalent.
Flow pattern directly behind A pillar is common - I assume it indicates the developing of a trailing vortex off each front pillar. Removal of mirror appears to have increased the area of this flow substantially. It would be interesting to do throttle stop drag testing with and without the mirror.
Old 09-22-2020, 09:16 PM   #7 (permalink)
マット
M_a_t_t's Avatar
Team Chevy
Motorcycle
Team Ford
How is this?
1995 Mercury Tracer
Old 09-22-2020, 09:46 PM   #8 (permalink)
Need standard / modified shots.
Old 09-22-2020, 09:53 PM   #9 (permalink)
マット
M_a_t_t's Avatar
Team Chevy
Motorcycle
Team Ford
I don't have a direct picture of the stock setup. I will get one tomorrow when it is daylight.
Here is a video I shot of it. I was trying to center the shot in the first 2 shots. The 2nd one didn't really work out. If you slow down the last few seconds it shows the modified version pretty well.
1995 Mercury Tracer
Old 09-22-2020, 10:33 PM   #10 (permalink)
Too many cars
Gen-1 Insights
Gen-1 Insights
I had also tested the right front window. That car never had a mirror there. I can't explain why the two sides were so different! Multiple photos show the same patterns. I taped over the mirror hole on the left side. I wish I had known about throttle stop testing when that car was still roadworthy. Maybe I'll do some testing with my Insight if I ever get it running correctly.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
JulianEdgar (09-23-2020)
