Old 05-29-2014, 02:06 PM   #21 (permalink)
Drive less save more
ecomodded's Avatar
90 day: 60.42 mpg (US)
I wonder why they didn't make it in the reverse trike design in that Nissan wide up front not behind ?
Must be a reason they choose the delta wing, perhaps they are hoping to "hover" around the track one day..
Save gas
Old 05-29-2014, 02:07 PM   #22 (permalink)
Valerie - '03 Honda Civic DX
90 day: 55.79 mpg (US)
I'd still buy an Elio over this car any day. (Assuming that I'll be able to do that anyway...)
Old 05-29-2014, 02:53 PM   #23 (permalink)
NightKnight
NachtRitter's Avatar
Helga - '00 Volkswagen Jetta TDI
Diesel
90 day: 54.39 mpg (US)
Mathilde - '99 Volkswagen Eurovan Camper
90 day: 16.87 mpg (US)
I think it'll be challenging for the driver to get a sense of the true width of the car. Probably end up knocking the rear fenders off on a regular basis.
Old 05-29-2014, 03:10 PM   #24 (permalink)
Good point, while a tapered back should be unusually difficult to hit.
Old 05-29-2014, 03:19 PM   #25 (permalink)
...beats walking...
The "Venturi Effect" occurs when air rushes between two close-proximity bodies causing them to be "sucked" together...such as two race cars!
Old 05-29-2014, 08:00 PM   #26 (permalink)
Would be interesting to say the least, but I wouldn't hold my breath for Nissan to release a road-legal version of the Delta Wing.
Old 05-29-2014, 09:32 PM   #27 (permalink)
P-hack's Avatar
awesomer - '04 Toyota prius
Nissan dropped out.
I like the idea of having a class of lightweight fuel efficient racers though, just too much to sort out with a delta. I also like keeping f1 as a "performance is the only consideration" class as well.
One other issue is the vortex generators creating downforce on the underside. It appears a slight bump into the air will destroy the downforce, as will getting a bit sideways, at which point your tires are skidding (braking) and you don't have the leverage at the front corners to help keep it flat. And people seem to enjoy knocking the delta around
Old 05-30-2014, 12:54 PM   #28 (permalink)
Anyone else bothered by the title? Should read something like "f You Want 70 MPG, Your Next Car May Have To Be A Gen1 Insight". My 2000 is still showing 71.2 average over 10 years/125K miles that I've owned it. (Admittedly it's not getting quite as good as it used to, since the lifetie average dropped from 71.4 a year or so ago.) So with 14 years of technical improvement, you have to go to something like that delta wing to get not even a significant improvement, but the same fuel efficiency?
Old 05-30-2014, 02:58 PM   #29 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
I saw a 4 wheeled one once.
Transmission type Efficiency
Old 05-30-2014, 08:36 PM   #30 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
That actually looks a lot better with the round headlights.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
