Old 04-15-2010, 11:17 PM   #181 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
At 2000rpm and 60mph, I figure you'll be able to fill one square inch with exhaust gas. A money no object tail extension would make use of that small amount of gas, but I'll probably ignore it for the most part.
Old 04-16-2010, 08:37 AM   #182 (permalink)
OurInsight - '06 Honda Insight
Yeah, doesn't seem like it would be worth any expenditure of scarce boattail money ;-)
Old 05-16-2010, 09:56 AM   #183 (permalink)
3-Wheeler's Avatar
AlienMobile - '00 Honda Insight
90 day: 80.05 mpg (US)
Originally Posted by moorecomp View Post
For anyone interested, I stumbled across these same lens at Farm & Fleet.
AutoZone has the entire light assembly. These are the lights I'll be using on the Insight. Also using some smaller side-mounted running lights, and separate reflectors. Nicely sized for good visibility.
Jim.
Old 07-11-2010, 05:52 PM   #184 (permalink)
botsapper - that link to the foam blocking is very nice, thanks
Old 07-11-2010, 06:51 PM   #185 (permalink)
Left Lane Ecodriver
Originally Posted by Rushd View Post
I guess to see some of the links and pictures I need to send 10 emails, well this is #2...
Welcome aboard, and you can delete your spamposts once you reach #10 and retain your signature-viewing privileges.
A fellow Insight owner? You should introduce yourself.
Regarding crosswind stability: Adding a lightweight boat tail should actually improve it. Because the tail moves your center of pressure rearward but barely moves your center of mass, a gust of wind that pushes your car to the right will also steer it to the left. Consider the effect of crosswinds on this modded M-B C-111 with and without the giant dorsal fin.
Old 07-11-2010, 10:29 PM   #186 (permalink)
Thanks Robert, I just introduced myself.
Old 07-11-2010, 10:30 PM   #187 (permalink)
Hi all, Sorry about the slams, but I wanted to see some links and pics that were only accessibe if I had posted 10 times (I'm sure you know the rule), so thanks for putting up with my sh*t posts...
Just deleted the slams and see that I only have 4 posts now....
Old 07-11-2010, 10:44 PM   #188 (permalink)
AND with only 4 posts I can't see the pics and links I wanted to see!!!
GRRRRR!
First PHEV Honda Insight (1st gen.) with Enginer.us system ericbecky Hybrids 31 12-19-2010 02:38 AM
Anyone know if there's an 1st gen Insight speed vs. MPG graph? MetroMPG Hybrids 10 02-21-2010 08:55 AM
What would you do to all-out modify (ecomod) a Honda Insight (gen 1)? MetroMPG Hybrids 25 11-26-2009 12:00 AM
News: Honda feeling pressure from Prius 3, planning to improve MPG of 2nd gen Insight MetroMPG Hybrids 14 07-31-2009 09:38 PM
Honda Insight Concept to Debut at Paris Int. Auto Show SVOboy EcoModder Blog Discussion 32 04-17-2009 10:45 AM
