Old 04-15-2014, 09:16 AM   #1 (permalink)
Smile Diesel Dilemas
We own a Ford F-250 that sucks down the fuel anyway...but when you add pulling a pontoon or a bumper pull camper to the equation...GEEZ!
I want to design my own light weight cab-over camper that will not only serve as a comfortable place to sleep, but also provide an aerodynamic function that will help when pulling our trailers.
FYI:I found this site while searching for DIY cabover camper designs.
Old 04-15-2014, 02:01 PM   #2 (permalink)
If your trailers aren't taller than the cab, a cab-over camper will add very much unwanted frontal area.
Old 04-15-2014, 03:03 PM   #3 (permalink)
Maybe a camper with a pop-up roof, even without the cab-over part (unless you could make it also foldable) would be a good solution regarding aerodynamics.
aerodynamic, campers, diy, pontoon boat, pop-up
