Old 06-09-2011, 12:10 AM   #11 (permalink)
Looks to me like no trans at all.
Old 06-09-2011, 07:57 AM   #12 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
Some of the conversions have transmissions, and obviously that would be preferable if it fits your budget and bike. But the torque curves on these is very flat once you are rolling, so you can "get away" without one, by making the same compromises as the no-transmission electric vehicles do.
I would love to see some transmission options, I know the old BSA and any divorced transmissions route, retro-direct doesn't work on a diesel, some folks have converted 2 and 4 stroke bike transmissions (would love to see a build thread on that) by sawing off the cylinders,etc, others have made custom gearboxes...
Old 06-09-2011, 10:39 AM   #13 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
I'm still working on the 4 stroke gearbox thing.... Figuring out which trans to use, since I have so many.
(Engines, projects, bills, etc...)
Old 06-10-2011, 10:33 PM   #14 (permalink)
Hal
V-twin diesels are fairly common: 25 HP V-Twin Diesel Engine Electric Start for instance.... The transmission was mentioned "CVT comet 94 "duster"" . CVT = continuously variable transmission
Old 06-10-2011, 10:48 PM   #15 (permalink)
Wow...I can sell that same engine for less than 70% of that price, if I get enough serious interest.
Old 06-11-2011, 07:54 AM   #16 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
That reminds me of the Changzuki.
Transmission type Efficiency
Old 06-11-2011, 07:58 AM   #17 (permalink)
dcb
needs more cowbell
dcb's Avatar
Problem is you throw a lot of efficiency away with a CVT when half the reason for converting to diesel is for maximum efficiency.
Old 06-11-2011, 12:15 PM   #18 (permalink)
I think this efficiency loss with CVT is a bit blown out of proportion, though.
Is it really that inefficient ALL the time, or only while it's actually doing something?
When it is only cruising, shouldn't it be about as efficient as a basic belt drive of the same ratio? How often do you really plan on accelerating?
Old 06-11-2011, 01:11 PM   #19 (permalink)
dcb
needs more cowbell
dcb's Avatar
For some reason I have %75 efficient in my head for that sort of CVT, but unfortunately I lost the trail.
Old 06-11-2011, 01:42 PM   #20 (permalink)
That one has a model that comet doesn't make any more, but it seems to me that 75% wouldn't allow that klr diesel to get up to 60mph+ with a 10hp motor... Let alone 120+mpg.
Effect of gear oil viscosity on transmission efficiency (Metro owners take note) MetroMPG EcoModding Central 44 12-08-2014 11:22 PM
Oil change recommendations? rjacob EcoModding Central 48 08-02-2010 05:04 PM
Oil Heater Blanket? cfg83 EcoModding Central 10 06-30-2009 12:30 AM
Alberta Oil Sands Gone4 The Lounge 8 02-19-2008 07:58 PM
Book report: The Last Oil Shock by David Strahan AndrewJ The Lounge 0 01-16-2008 11:55 PM
