Old 02-20-2014, 01:45 PM   #1 (permalink)
Diesel FTW
PAFirefighter11's Avatar
Golf TDI - '03 Volskwagen Golf TDI GL
90 day: 44.63 mpg (US)
Diesel - Warm or Cold?
With a diesel motor is a warm or a cold air intake going to provide better fuel economy? I've seen mixed responses on some other forums so I figured I'd post here. Does anyone have personal experience with this?
Thanks.
-Rick R
-'03 Volkswagen Golf TDI (49.9 MPG - Stock with Eco Friendly Tires
-'98 Jeep Grand Cherokee 5.9L - 32" MTZ's, 4.5" lift (11.5 MPG)
-'98 Pontiac Firebird Trans Am WS7 5.7L (22 MPG)
-'01 Pontiac Firebird Trans Am WS6 5.7L (22 MPG)
Old 02-20-2014, 02:23 PM   #2 (permalink)
Master Ecomadman
arcosine's Avatar
sc1 - '98 saturn sc1
Team Saturn
90 day: 43.17 mpg (US)
rans - '97 rans tailwind
90 day: 28.25 mpg (US)
red bug - '00 VW beetle TDI
big tractor - '66 ford 3400
90 day: 58.42 mpg (US)
RV - '88 Winnebago LeSharo
90 day: 16.67 mpg (US)
My guess is warm air in the winter would be better, try it.
- Tony
Old 02-20-2014, 06:06 PM   #3 (permalink)
Jyden's Avatar
Enduro E-bike - '11 PowerPedals Enduro
90 day: 2236 mpg (US)
Jota - '14 Toyota Yaris Hybrid H1
90 day: 53.11 mpg (US)
Thanks.
Cold - all the time, the colder the better. Cold is more oxygen for the combustion.
My Yaris Hybrid thread:
http://ecomodder.com/forum/showthrea...s-c-27995.html
Old 02-20-2014, 08:02 PM   #4 (permalink)
NightKnight
NachtRitter's Avatar
Helga - '00 Volkswagen Jetta TDI
Diesel
90 day: 54.39 mpg (US)
Mathilde - '99 Volkswagen Eurovan Camper
90 day: 16.87 mpg (US)
Yep, colder is better... no WAI for the TDI.
The Following User Says Thank You to NachtRitter For This Useful Post:
Cobb (02-20-2014)
Old 02-20-2014, 08:56 PM   #5 (permalink)
Master Ecomadman
arcosine's Avatar
Team Saturn
So you are saying that diesels get better mpg in the winter, -0F temperatures? I find that hard to believe.
- Tony
Old 02-20-2014, 09:09 PM   #6 (permalink)
Diesel FTW
I think the winter thing is hard to determine because they switch from #2 diesel to the winter blend of #1 or a mix of both. This reduces FE in and of itself.
-Rick R
Old 02-20-2014, 10:35 PM   #7 (permalink)
NightKnight
Diesel
No, I am not saying that and I did not say that. The engine itself needs to be warm while the intake air needs to be cold. In the winter, the diesel engine has a hard time getting warm; if the engine can't get up to operating temp there will be a negative effect on FE. However, a WAI still doesn't help; the biggest contributor to keeping the engine temp down is the radiator/coolant. So to get the best winter FE you want to have an engine block / coolant heater, a grill block, and no cabin heat. And cold intake air so that you get the most complete combustion (and therefore best power output for the fuel consumed). This is particularly important for a turbodiesel since the intake air is heated by running through the turbo.
Of course there are additional contributors to lower FE in winter, such as the fuel difference mentioned by PAfirefighter. I'd guess running without cabin heat might be unacceptable to some drivers too.
A study of the effect of intake temp on a normally aspirated diesel engine was done and is available here: http://www.oricpub.com/SE-1-1-2-3.pdf
Old 02-20-2014, 11:03 PM   #8 (permalink)
Master Ecomadman
arcosine's Avatar
Team Saturn
So you are saying that more air in the engine the better the mpg, well then why not have a big engine that sucks a lot of air in and that should get better mpg than a small engine that sucks less air in at a given output. I still don't follow the logic, since at partial throttle there is more excess air in a Diesel and less fuel but yet the sbfc is not better.
In the report that you site, they don't mention changing the injection timing for optimum torque at the different temperatures tested.
- Tony
Old 02-21-2014, 02:54 AM   #9 (permalink)
NightKnight
Diesel
Sorry, not seeing how you're coming to the conclusion that a bigger engine should get better mpg than a smaller engine based on the idea that higher air density is beneficial for FE. It's the ratio of air to fuel; the larger engine would presumably consume more fuel along with more air so the ratio would essentially be the same as the smaller engine.
Is it your belief that warmer intake air in a turbodiesel will get you better FE than cooler intake air? If so, do you have some data supporting that? Does that mean turbodiesels should not be seeing a benefit from intercoolers?
Old 02-21-2014, 03:44 AM   #10 (permalink)
TexasThunder Avg MPG 54 - '08 Toyota Prius Base
cold air intake is way way over sold. Ebay has plenty of them. The benefit is marginal if not nothing on some vehicles
