Old 12-11-2010, 12:09 PM   #21 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
Originally Posted by Duffman View Post
Pulling the EGR cable throws a code on some vehicles. This puts them into a limp mode which adjusts injection timing, messes with the VGT boost tables etc. Less EGR is better for economy but it may be offset by the computer depending on the vehicle.
But if the computer doesn't know....
I'm not coasting, I'm shifting slowly.
Old 01-03-2011, 02:42 PM   #22 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Update for the TDI
After much reading and talking to mechanic friends I decided to replace the cracked egr pipe and keep the car egr system stock. When I disassembled the egr system I found that only the lower pipe was broken and I had only a thin coating of soot, no intake or egr cooler clogging at 60,000 miles. The parts cost is about $100 and I did the work myself.
I did find several missing and cross-threaded bolts from the last time the dealership did this job (warranty repair). The egr cooler is designed to be solidly mounted to the intake manifold. Mine was loose and only supported by the two egr pipes. No wonder the pipe fails!
I decided that replacing the pipe myself is the most cost effective repair, reduces Nox emissions and may give me the best mpg in the VW TDI. The tricks done to the car's computer would have to be very carefully worked out to keep injection timing optimal as designed and I wasn't willing to risk losing mileage.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
Cooled EGR Piwoslaw EcoModding Central 51 05-08-2015 04:30 AM
How do you eco-drive a diesel ? groar Hypermiling / EcoDriver's Ed 122 05-24-2014 09:05 PM
Theory: not just disabled cylinders, but a power/compound cylinder engine mechman600 EcoModding Central 18 04-16-2010 07:02 PM
EGR dilution for more MPG? cfg83 EcoModding Central 18 04-29-2008 09:11 PM
News: Only 6% of Americans think diesel will succeed as powertrain option MetroMPG General Efficiency Discussion 38 02-14-2008 02:23 AM
