Old 05-20-2011, 12:07 AM   #11 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
It sure sounds like a bad connection or a dead battery, I had trouble for a short time when the weather started getting cooler and I was driving early mornings and late evenings with my head lights on, I found that my battery was not fully charging and I was about to buy a new battery but figured that instead I would put it on a slow charge over night and I haven't had an issue with it all winter and in to the spring now.
So I would say to get your connections all cleaned up, make sure the battery is fully charged (drive an hour or more, or put it on a charger) and you should be fine, popping the clutch is always a good idea in my mind as you give your battery that extra little boost instead of putting a big load on it right away.
Old 05-20-2011, 03:43 PM   #12 (permalink)
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
Everything points to bad battery connections. A weak/dying battery will be under 12V, and CACivic's battery had 13V. My battery gets weak with too much P&G, especially in the winter, so I plug it onto a trickle charger then. But even fully charged after an 800 mile drive, it only shows 12.3V. I don't worry about it not starting until battery voltage drops <11.6V.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
The Following User Says Thank You to SentraSE-R For This Useful Post:
California98Civic (05-20-2011)
Old 05-23-2011, 01:00 AM   #13 (permalink)
Lead-footed Econewbie
Ceffy - '97 Nissan Cefiro 25 excimo
90 day: 25.21 mpg (US)
Demio - '07 Mazda Demio Sport
90 day: 30.99 mpg (US)
What happens when you whack the starter with your hammer? Does it suddenly turn better and kick?
Can't get to the youtube vid but I had to fix almost exactly this a while back, thought it was bad connections, worked through everything electrical until I tore down the starter.
Yup.
The brushes were worn out, meaning the starter would barely turn, and this would also not send enough kick for the starter to engage and the contacts to then send full battery oomph through it.
New brushes for the starter, as well as a clean out and high-temp grease for it, it was just fine. Is this a high mileage car?
So if it isn't a fuse, relay, wire or bad earth, it'll be shot brushes in your starter.
