Old 02-24-2010, 02:46 PM   #1 (permalink)
DIY Alternator Controller
Since Paul & Sabrina seem to have made EcoModder the center of DIY controller development this would seem to be the appropriate forum for a thread for a DIY alternator controller.
I have been planning to build a reverse trike using twin alternators for power and from what I've found on the web people are using them as motors controlled by RC escs. There are claims of power up to 5 HP.
I envision a 10kw max bldc controller with provision to vary the rotor current to control torque. Higher current at low rmps increases torque.
If I missed something in my forum search please direct me.
The Following User Says Thank You to salty9 For This Useful Post:
rvind2008 (05-23-2011)
Old 02-24-2010, 02:52 PM   #2 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
I've actually been chewing on that myself, main problem is retrofitting hall effects or some other position encoder so you can have nice startup torque. The field draw doesn't look to horrible and may provide for better dynamic range, like sepex does. Also I'm not sure what effect the angled field interface on the rotor will have or the overlapping coils in the stator. Those might be there for smooth power, at efficiencies sake.
The Following User Says Thank You to dcb For This Useful Post:
Old 02-24-2010, 03:14 PM   #3 (permalink)
Dave,
This is just a counter to reach 5 messages
Old 02-24-2010, 03:31 PM   #4 (permalink)
Dave,
I'm back with a couple of links you might not have found:
Endless-sphere.com • View topic - e-Buggy: Alternator Conversion
Endless-sphere.com • View topic - Adding hall sensors to outrunners
Analysis of a REEM inadvertently used in a reverse power flow condition. - RC Groups
I have not put anything on paper or a breadboard yet but I'm planning on making the controller modular with mcu, optoisolator, driver and power boards.
This should make troubleshooting easier. Lots of little hairballs instead of one big one.
Chuck
Old 02-24-2010, 04:40 PM   #5 (permalink)
What would be the advantage to having an alternator controller?
The Following User Says Thank You to Angmaar For This Useful Post:
Old 02-24-2010, 06:01 PM   #6 (permalink)
When properly controlled an alternator, like any generator, is a motor. They also happen to be cheap, durable and readily available.
Old 02-24-2010, 06:50 PM   #7 (permalink)
Oh so you are using it as a cheap motor.
Old 02-24-2010, 08:48 PM   #8 (permalink)
dcb
needs more cowbell
dcb's Avatar
I've dug through this thread a lot too
How to Convert an Alternator to A Motor - RC Groups
but a propeller (glorified fan) is a much more predictable load than a car/bike motor so they get away without position sensing ok at startup
I actually have an alternator that I routed the field and stator leads externally on, sitting on the bench.
Old 02-24-2010, 09:45 PM   #9 (permalink)
I followed that thread quite a while until it got so heated.
I'm planning on using an Atmel mcu as I already have a STK500 programmer. I've ordered an optoisolator board and am trying to determine the mosfets and drivers to use. Any suggestions will be appreciated.
Old 02-24-2010, 10:08 PM   #10 (permalink)
dcb
needs more cowbell
dcb's Avatar
I'm planning on using the atmega 168/328 and borrowing heavily from the atmel site.
i.e. AVR447 Atmel Products - AVR Solutions - Motor Control Applications
Looking to retrofit halls and drive it w/sine waves and experiment with the field strength.
Also found a dirt cheap avr isp clone ($10)
Prototyping PCB I grabbed a pic programmer too for giggles.
DIY: OEM VX PCV and Info TomO DIY / How-to 4 04-02-2011 09:38 AM
AC vs DC for DIY MazdaMatt Fossil Fuel Free 15 03-06-2009 09:33 AM
Three Dirt Cheap DIY Electric Cars - Part 4 SVOboy EcoModder Blog Discussion 3 12-12-2008 08:14 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 04:10 PM
Three Dirt Cheap DIY Electric Cars - Part 3 SVOboy EcoModder Blog Discussion 0 12-05-2008 10:30 PM
