DIY - Black Trim Painting
So, guess who's painting all his trim? This is mainly a DIY for my site but I like to post my stuff up here since this is where I got my start writing DIYs, :), nothing to do with FE of course.
Anyway, it's unfinished, but big, so working in parts! Before shot: http://xs205.xs.to/xs205/06340/DSC00494.JPG Before bumper: http://xs205.xs.to/xs205/06340/DSC00495.JPG Using two or three cans of this for the whole deal: http://xs205.xs.to/xs205/06340/DSC00510.JPG Piece of coroplast over a trashcan in the garage, my painting center: http://xs205.xs.to/xs205/06340/DSC00511.JPG An MID picture in here for no reason, that comes out to ~52 mpg for a 3 mile cold start, not bad: http://xs205.xs.to/xs205/06340/DSC00512.JPG Start by taking the two screws that hold the corner lights in and taking the lights out: http://xs205.xs.to/xs205/06340/DSC00513.JPG http://xs205.xs.to/xs205/06340/DSC00514.JPG Make sure to store everything nicely: http://xs205.xs.to/xs205/06340/DSC00515.JPG Tools needed, that socket is a 10mm: http://xs205.xs.to/xs205/06340/DSC00516.JPG Take these two out on each side: http://xs205.xs.to/xs205/06340/DSC00517.JPG And this one on the bottom, this will allow you to remove the t-bar: http://xs205.xs.to/xs205/06340/DSC00518.JPG Get these two bolts gone: http://xs205.xs.to/xs205/06340/DSC00519.JPG Two of these on each side come out, might have to move the wheel a bit: http://xs205.xs.to/xs205/06340/DSC00520.JPG Two of these corner jobs: http://xs205.xs.to/xs205/06340/DSC00521.JPG Move the t-bar to expose these three things: http://xs205.xs.to/xs205/06340/DSC00522.JPG Start pulling the bumper off and unplug the bumper lights: http://xs205.xs.to/xs205/06340/DSC00523.JPG But it somewhere not scratchy: http://xs205.xs.to/xs205/06340/DSC00524.JPG To get at the fenders undo these two: http://xs205.xs.to/xs205/06340/DSC00525.JPG These three up top: http://xs205.xs.to/xs205/06340/DSC00526.JPG This one in the crack. Use an open-ended wrench and open the door, stand outside and reach over and do it from the crack, you'll see what I mean: http://xs205.xs.to/xs205/06340/DSC00527.JPG Get these screws on that bottom trim piece: http://xs205.xs.to/xs205/06340/DSC00528.JPG The bolt on the bottom as well: http://xs205.xs.to/xs205/06340/DSC00529.JPG When it's off hit up these two last bolts for the fender: http://xs205.xs.to/xs205/06340/DSC00530.JPG Get bored and work on this piece of trim instead: http://xs205.xs.to/xs205/06340/DSC00531.JPG Blast it with the hose, the suds, the hose: http://xs205.xs.to/xs205/06340/DSC00532.JPG Then clean it with alcohol and let it dry: http://xs205.xs.to/xs205/06340/DSC00533.JPG Here it is drying: http://xs205.xs.to/xs205/06340/DSC00534.JPG Work on the rocker panel while it dies, these plastic screws suck, you need to be very careful, especially with the ones that are more exposed: http://xs205.xs.to/xs205/06340/DSC00536.JPG Yay, I stripped one: http://xs205.xs.to/xs205/06340/DSC00537.JPG Grabbed the edge with some pliers and turned it out like that. I always leave the last few threads in the thing and use them to pull the whole thing out as one: http://xs205.xs.to/xs205/06340/DSC00538.JPG Some more up top: http://xs205.xs.to/xs205/06340/DSC00539.JPG Even more up top: http://xs205.xs.to/xs205/06340/DSC00540.JPG Now, get bored of that and work in the other piece that on the door. Take off this 10mm plastic nut: http://xs205.xs.to/xs205/06340/DSC00541.JPG This is how it clips in along the bottom, the first task is to unclip: http://xs205.xs.to/xs205/06340/DSC00542.JPG Half unclipped first: http://xs205.xs.to/xs205/06340/DSC00543.JPG Go ahead and fully unclip and then push up to get it off the metal rail: http://xs205.xs.to/xs205/06340/DSC00544.JPG Get bored again and decide to finish the fender, undo all the plasticy junk in the wheel well: http://xs205.xs.to/xs205/06340/DSC00545.JPG Fender out: http://xs205.xs.to/xs205/06340/DSC00546.JPG Flip it over to expose the two clips for the trim piece, pop them with some pliers: http://xs205.xs.to/xs205/06340/DSC00547.JPG Yay, it's so pretty: http://xs205.xs.to/xs205/06340/DSC00548.JPG Hit that first piece with some paint, drying at this point: http://xs205.xs.to/xs205/06340/DSC00549.JPG Not that this is a vertical line spray, you need to hold the can vertical to keep it going and work in a smooth, sweeping motion: http://xs205.xs.to/xs205/06340/DSC00550.JPG With time, there will be more. |
those plastic retainers w/ small plastic screw in the middle can be removed veerryy easily with a small pointed pick. Put the point of the pick into the screw portion just under the head where it meets the wide part of the body and pry gently. a screwdriver will tear them up in a heartbeat, once the head is out 4 or 5 threads just pull like you were. whole retainer comes out and is re-usable. BUT if you accidentally destroy one they are available on NAPA.com i believe they were 10 in pack for $5. S.
That's for the tip! I never even though of buying more, :)
I'll have to get a pick at some point, too. |
I didn't think about buying them until i need quite a few for my interior. My local Chevy dealer wanted $1.5 (approx, my memory is fading) for a two pack. Google here i come. lo and behold it led me straight to NAPA. S.
Which is why I don't like going to a dealer for parts because everything costs 3 times as much as you can buy it across the street!!!
Is that a texture paint?
Because I've been considering how to finish my JettKamm - and I'm thinking of a black texture - like die injected plastic trim bits. Will hide imperfections, give it a "stock" look and is generally easy to apply. Or I might buy my father (who does finishing professionally) a throw away gun and see about painting it with glossy black epoxy paint :) And omg picture overload! |
Hi, I am a 24 years old. I am currently taking a beginners painting class, and I am also an art major. I seem to always fall under the same style of painting, mostly impasto impressionism. I would really like to break away from this style. I thought about doing my next assignment based on a portrait with best technique, but I am afraid on how to begin with this and what sort of brushes I should use. Any helpful recommend will be greatly appreciated.
Hi, I love tomato bisque soup and I'm wondering if you have any suggestions on how to make my spackle taste more like tomato bisque soup. Right now I have a lovely bunch of coconuts sitting in a row; large ones, small ones, some as big as your head. But, yes, we have no bananas today.
http://spidermouse.us/images/smilies/freak.gif Seriously? Nice thorough work so far SVO :thumbup: |
I apparently need to move to warmer climes; it looks warm there with green grass and no socks/shoes on 11/30... |
I am also confused.
