Old 05-03-2011, 12:39 PM   #341 (permalink)
Originally Posted by adamj12b View Post
Currently the revolt is basically a constant current power supply. The duty cycle is always changing to maintain a steady current output.
You forgot to add the caveat "with a suitably large inductor". I'm sure you know this, but not the casual reader.
Without output smoothing, the Cougar will have bad behavior with many batteries. LiFePO batteries, which look pretty much like capacitors in the time frames involved, will absorb huge current pulses in the first few microseconds putting the controller at risk. Most lead-acid batteries will heat rather efficiently charge.
The Cougar runs the PWM at about 8KHz or 16KHz, which requires a pretty big inductor. It could be much smaller with a frequency 4x-10x higher. And a smaller inductor might have lower resistive losses, which could offset the higher switching losses. Perhaps.
The Following User Says Thank You to DJBecker For This Useful Post:
flores (05-03-2011)
Old 05-03-2011, 02:46 PM   #342 (permalink)
EV Connoisseur
I didn't. I'm fairly good with digital electronics, but this power electronics is fairly new to me.
Dumb question: I thought that the capacitors smooth out the output voltage? How does an inductor help with this? And with inductor you mean a coil with a wire wrapped around/through it right?
How can I tell that i'm doing it right/have the right inductance? can this be measured? seen on a scope?
Thanks
Old 05-23-2011, 01:52 PM   #343 (permalink)
ElectricZX2 - '98 Ford ZX2 Cool Coupe
90 day: 140.91 mpg (US)
I asked Paul about using cougar as a charger and I too forgot about an inductor. Otherwise I think it would be relatively easy to switch back and forth between contoller mode and charger mode. He wondered if the motor could be used as an inductor when in charging mode. Anyone know if this could work? I want to try to use cougar as a constant current source for charging my batteries...I don't care about the output voltage because I plan to just open a relay on the input when my pack gets to a certain voltage. Otherwise, what about just using the stator out of an old electric motor?
Old 05-23-2011, 11:46 PM   #344 (permalink)
The motor can indeed be used as the inductor, but you risk patent infringement with Tesla. ( the car Co. not the guy )
Old 05-24-2011, 09:34 AM   #345 (permalink)
Hm, better disable it if I ever want to sell the car for profit . Could you just wire the stator posts in series with the charger output? I'm assuming a 9" motor would be a large enough inductor...l.
Old 05-25-2011, 01:44 AM   #346 (permalink)
vei
Hi, I haven't read the whole post but I was interested. I saw you were talking frenquency vs inducter size.
I wanted to say I'm in embedded by profession, so if you have specific needs I might be able to help. I have one of my toy with a 32 bit IC running 2 pwm at 5000hz.
Just saying it's no problem, and switching frequency is limited by the mosfet's turn off time.
I'm starting work on a 3ph open source drive for 3ph induction motors to prepare for my build. So I might as well think of the chargers now since the motor has useful coils in it.
Let me know if you are covered on the uC side
keep up the good work
'94 chevrolet fullsize 5sp 13.5 -> 11.40
Old 07-12-2011, 05:53 PM   #347 (permalink)
apowers's Avatar
What is this?
I found this and had to have it because of it's size. It looks like a big inducter but I think it may be a transformer.
Old 07-13-2011, 12:52 AM   #348 (permalink)
I belive its a transformer....
Old 07-13-2011, 12:54 AM   #349 (permalink)
I have some of those kind of transformer (toroidal), but for audio amplifier, centre tapped step down..
thanks
Old 07-13-2011, 12:27 PM   #350 (permalink)
apowers's Avatar
Yes I think it is a transforner. I'm not sure I can use it for anything other than a boat anchor.
Alvin
ev charger
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1041 07-28-2014 09:19 AM
Any interest in developing an open source fuel economy gauge/computer? MetroMPG OpenGauge / MPGuino FE computer 182 06-25-2010 07:00 AM
Open source PCB design dcb OpenGauge / MPGuino FE computer 39 04-25-2010 09:18 PM
Open Source electric conversion information bennelson Fossil Fuel Free 8 02-14-2009 11:23 AM
Open Source LEV Controller FrankG Alternative Transportation 1 03-24-2008 03:10 AM
