Old 07-15-2014, 09:20 PM   #1 (permalink)
Supra - '88 Toyota Supra
superhawk - '98 Honda superhawk
Last 3: 27.62 mpg (US)
Lesabre - '96 buick lesabre
3800
90 day: 25.85 mpg (US)
Saturn - '97 Saturn Sc2
Team Saturn
Sports Cars
90 day: 39.12 mpg (US)
Truk - '99 Ford F150
Team Ford
Pickups
90 day: 24.43 mpg (US)
Golf - '03 Vw Golf
90 day: 38.57 mpg (US)
How to 3800 powersteering delete
So I recently unhooked the power steering in my lesabre and here's how I did it
I got the parts from napa
Parts needed
Shorter serpentine belt p.n. 25-060670
90mm tensioner pulley p.n. 38007
The belt is a tight fit and has to be because the tensioner will be about at the end of its travel hence the larger pulley. What I did was to keep most of the stock routing except instead of the belt going from the water pump to the belt goes straight to the alternator
Old 07-16-2014, 04:39 PM   #2 (permalink)
How does it feel with the power steering disconnected?
Old 07-16-2014, 04:47 PM   #3 (permalink)
herp derp Apprentice
Saturn-sold - '99 saturn sc1
Team Saturn
90 day: 28.28 mpg (US)
Yukon - '03 GMC Yukon Denali
90 day: 13.74 mpg (US)
who needs power steering when you're in nebraska, i dont know if ive even needed the steering wheel going through.
on a less sarcastic note, my '94 olds 88 was awful, largely due to strut mounts hanging up
Old 07-16-2014, 05:42 PM   #4 (permalink)
How did you know the part for the new shorter belt? Did you measure it or use the part from a model not equipped with power steering?
Old 07-16-2014, 06:23 PM   #5 (permalink)
3800
Team Saturn
Sports Cars
Team Ford
Pickups
Golf - '03 Vw Golf
I measured then found a belt that was the right size I have no idea what vehicle its actualy for. Its a bit of work to steer but I still have the lines hooked up to the pump
