Go Back   EcoModder Forum > EcoModding > The Unicorn Corral
Old 05-07-2008, 05:06 PM   #1 (permalink)
Do air tabs work?
Hi (New Post),
I'm Martin, a biz student/Entrepreneur located in Boston but originally from Toronto.
I've been looking into retrofitting cabs/buses/trucks with simple aero mods. In the past, I have started several successful unrelated businesses and am eager to try and commercialize aero mods. I've been looking at the Canadian company aeroserve technologies ltd. (the makers of the airtab) and am considering pursuing a business venture with them.
Can someone please enlighten me to whether these tabs would work on a coach bus or if these vortex generators actually achieve a 2-8% increase in MPG?
Cheers,
Martin
Old 05-07-2008, 06:48 PM   #2 (permalink)
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 Scion xD RS 1.0 #1633
90 day: 35.45 mpg (US)
Silent Silver Killer - '10 Honda Insight EX
90 day: 51.5 mpg (US)
Good question ... a friend of mine has them all along the roof line of his Scion tC and swears by them ....
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
Old 05-07-2008, 07:09 PM   #3 (permalink)
Red
Red's Avatar
They didn't do squat on my Jeep cept keep the back window slightly cleaner on the hard top
The Following User Says Thank You to Red For This Useful Post:
undeRGRound (11-11-2014)
Old 05-07-2008, 09:23 PM   #4 (permalink)
Grrr :-)
Nerys's Avatar
Cherokee - '88 Jeep Cherokee
90 day: 19.44 mpg (US)
Ryo-Ohki - '94 Geo Metro Xfi
90 day: 50.15 mpg (US)
Vger 2 - '00 Plymouth Grand Voyager SE
Ninja - '89 Geo Tracker
90 day: 30.27 mpg (US)
got some links or pictures ? Anyone have access to a wind tunnel?
Old 05-08-2008, 02:07 AM   #5 (permalink)
Originally Posted by MartinShen View Post
Do air tabs work?
No.
http://autospeed.com/cms/A_3061/article.html
Old 05-08-2008, 03:58 AM   #6 (permalink)
Grrr :-)
Nerys's Avatar
Ahhh I know what these are. I used these on my CO2 Cars!! (you always had an exit flat because of the minimum reqquirements for the Co2 cart hole dimensions this smoothed out the airflow by generating a vorte of air current. Shaved almost 2 tenths of a second off my Co2 cars run time! (same model ran 10 runs without then I added them and ran it 10 times again) I was impressed. I am not as certain how this would work scaled up. My models had wacky reynolds numbers that just do not scale up.
Might be worth trying though as they are very easy to make yourself. I do not think they would help that much on a car like mine but if you do have some sort of hatch it might work. If you are good at building them it might be worth a try IE it would not cost much at all so if it did not help you lost nothing except some time.
NOW in my case I was producing THRUST from the rear. The the vorticies had somewhere to go IE merge with. The thrust plume from the CO2 Cart. I would not think they would have a beneficial effect on a ballistic example such as our cars (its thrusting but via the ground so that does not count aerodynamically)
They might clean up airflow but they will not reduce drag UNLESS they eliminate an increase in drag from sloppy flow that is larger than there own drag contribution.
Huh at $2.50 I would not even bother making them myself and just buy them. Suck though no quantity discount. the 80 unit kit for truck/trailer is the same $2.50 per price.
The Following User Says Thank You to Nerys For This Useful Post:
Old 01-09-2011, 11:00 AM   #7 (permalink)
pavement pounder
Smurf - '11 Honda Civic LX Sedan
90 day: 33.38 mpg (US)
Originally Posted by tjts1 View Post
you say no but the article states that there is a minor potential for increase... what gives?
The Following User Says Thank You to aggie sig For This Useful Post:
capnbass91 (09-05-2011)
Old 01-09-2011, 03:11 PM   #8 (permalink)
I had them on my xA and they hurt my FE.
Old 01-09-2011, 11:35 PM   #9 (permalink)
Aero Deshi
ChazInMT's Avatar
MagMetalCivic - '04 Honda Civic Sedan EX
Last 3: 34.25 mpg (US)
They work great, I think 2-8% FE Gains are way too conservative, I bet you get 40-60% FE Gains....In fact, I'll bet you could just put them on your car and they'll just push it down the road on their own...so just go ahead and rip the engine out of your car and let the aitabs just push you around town. You better have good brakes to keep your speed in check.
The Following User Says Thank You to ChazInMT For This Useful Post:
MobilOne (04-28-2015)
Old 01-10-2011, 05:41 AM   #10 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
I'd say they're just oversized for use on a car.
Turbulator tape for gliders is (less than) 1mm thick, but AirTabs are 25mm or 1 inch thick as they were intended for use on big trucks !
VGs also add drag by themselves, so you need to overcome that first before you start gaining.
MetroMPG found they smoothed out the airflow on the back of a small sedan.
Red above found them to keep the rear window cleaner (indicating reduced turbulence at the rear).
They were found to improve stability when mounted underneath an Insight (1gen).
But so far, they weren't found to reduce the fuel consumption by EM members.
The Following User Says Thank You to euromodder For This Useful Post:
Comparing Warm Air Intakes (WAI) & Cold Air Intakes (CAI) toomuch EcoModding Central 27 11-20-2022 04:24 PM
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
Conversion idea, 2L inline 4 -> piston boosted 1.0L 2 banger? Warning....Long thread JoJotheTireMan EcoModding Central 56 06-12-2011 03:09 AM
The Mechanism Behind Flow Separation LostCause Aerodynamics 46 07-15-2010 07:38 AM
OEM Air Injection, Yay or nay? Dane-ger EcoModding Central 11 01-14-2008 10:05 AM
